Hi guys.
Has anyone installed a PC in a V35?
I'm thinking about it at the moment.
There are two options.
OPTION 1
Buy a PC Tablet. Find a way to mount it so it does not look bad. They can be powered by a car charger which can run behind the centre console. For good sound output I can run an AUX cable (again behind the centre console) to avoid cable visibility.
Many PC tablets have a GPS built in which is a bonus. This tablet can be removed easily to avoid break-ins.
OPTION 2
Take a small laptop. Take it apart. Mount the screen so it looks professional. Extend the cables and put the keyboard in a sliding mount above the glove box where the GPS DVD reader currently sits.
Preferably buy an aftermarket touch-screen for easy use.
This will require more work. It also will need a V converter to create a steady electricity flow. (Car battery is not very good at this).
This will mean better PC, more storage, being able to play DVD.
To run GPS I will need to purchase some additional bits. Not too expensive though. Between $150-$250. Since I all ready have a laptop I can use.
Has anyone done something like this? Anything to consider before i start playing with it?
I want to keep the centre console as it is
https://www.sau.com.au/forums/topic/341185-installing-a-pc-in-v35/
Sounds like something no one has done in Australia. Go over the g35 forums and im sure some nut case in the USA has riced his vehicle out so much that it has 3 computers (1 dedicated to playing re-runs of The Fast and the Furious) and even a vending machine inside their car.
Edited by jawrgy
Hi guys.
OPTION 1
OPTION 2
Try searching 'carputer' - there are quite a few discussions which you may find useful.
This is a really good one:
http://www.skylinesaustralia.com/forums/Ca...amp;hl=carputer
And then there's the other 'general' discussions on 'em:
http://www.skylinesaustralia.com/forums/Ad...amp;hl=carputer
Good luck
He he, funny.
Good luck
thanx for the links.
I have a plan in mind, just the whole wiring process, taking bits apart and putting them back together... well.. i will need to find someone to do it. Just not enough hours in the day.
Will start purchasing bits and peaces and see where it goes from there.
If u looking for sum1 to do it . Go to Autotainment in Burswood ask for Brian Wallis. Hes done heaps of these cars. installs dvd sat nav and evrything. Did mine and a lot of oder v owners.
Thanx, i will see him soon.
If you dont mind I have few questions.
1. did you buy the dvd + Gps from him or did he just install it.
2. How much did it cost roughly?
just wondering so i know what to expect.
If you guys thik he is good, you can leave him e erview here:
http://maps.google.com.au/maps/place?rls=c...092508294404230
Reviews will help his Search Engine Visibility, which means more people will find him easier when they look for his service.
Thanx for the help
Edited by 350gt2003
I think he charges around $2500 for everything which includes dvd player sat nav and australian t.v. I jus did the dvd player which i bought from him. Charged me 800 wid installation . Puts a new system but outputs thru the factory screen.
I don't have a V35 but I've put carpc's in my 32 and my Stagea.
I use the VoomPC barebones setup from mini-box.com, chuck a locally sourced stick of ram, hdd and dvd drive in there and run 7" non-motorised in dash touchscreen (removed it from the 32 while it's off the road and put it in the wagon), when the 32 is back on the road I'll most likely get one of those USB touchscreens that are available now.
Well, i did mine about 6 months ago and it's still running sweeet.
Here's my post on that.
G33k helped with idea of using a fabricated frame for the screen, which is the most fidgety part to do :D
I can vouch for Brian too since he installed my DVD deck, but $2500? Really?
Just do your research and buy the ingredients yourself. You'll be amazed of the savings :D
or one of my mates has an ipad installed in her car
looks pretty mad
thank you all for the input.
Ripstah - This was a option i considered. Was thinking to put in one of these:
http://cgi.ebay.com.au/7-Windows-CE-5-WiFi...=item45f58f3f20
If i do, i just need to find someone to create a good mount, connect to current stock V35 system (maybe AUX) and runn the power to it.
Thats all i would need for now.
hmmm...
o.O nice and cheap!
are you looking to keep your OEM screen and keep all the features ?
BTW. please let me know how you go, ive been looking around to getting a double din installed and so far best quote ive gotten is $1600. but without the OEM screen and features.
hi,
see first i thought of something ike this:
http://cgi.ebay.com.au/7-Dash-Car-CD-DVD-P...=item4aa07e6f2d
then I saw the google android software run tablet> which can do everything i need.. Play music, video, gps + all the google apps you can install that i would like in the car. I use google and google apps for everyday work and research, so this would be perfect.
I really want to keep the stock look as mine is still working. if it ever dies i can always change it.
However i didnt want to pay another 300-450 for a new dash interface: http://cgi.ebay.com.au/2003-2004-INFINITI-...=item53d99eacce
so if i buy a PC tablet, migt not be the one i used s example previously, can be more expensive version. All i would need is to wire a headphone jack to the current CD player (using heaphone to AUX cable).
Then run the car charger behind the dash for better look.
Then all i will need to do find a spot to put the PC in.
There is a cool iPad mount you can buy. cant find it now but similar to this: http://cgi.ebay.com.au/CAR-Stander-CRADLE-...=item588a7d45cb
This way i can connect it easily and take it out when i leave the car overnight.
Will need to confirm if this is doable from electricians point of view. It should be if we use a simple car charger, but better to check.
Will search for a decent pc tablet and will buy it... then ill take it from there.
Edited by 350gt2003
    • So it should work in my case?  I does not say R34 but it say push(i have push gearbox/clutch right now) No i wont...and i do not drift/race or do anything crazy with car so even a small box should be ok for a couple of months
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
