i see that the admins are just trying to make a safer place for us to trade through, but i do agree with the majority of the people and it sure is a pain in the butt! i think it would be better for donating and club members to be able to edit posts in all the non-forsale sections at the least. it would make everything alot easier and cleaner, wouldn't it? look at the users feedback also. after all, we are what keeps this site going!
Hey i've donated, can't edit for sale info.
Most people browsing the for-sale section will only look at the title of every thread. Not being able to edit all the old stuff out reduces the chances of the last few items selling, and makes for a very messy section.
GIVE ME MY EDIT PRIVILEGES BACK GOD DAMMIT.... :unsure:
it is a pain because you cant edit the first post which most of the time is needed so you can update price drops, add pictures, etc.
what i suggest is: allow editing of the first post (but not the title of thread) but also allow editing of the sub-title of the thread (so if the item is sold we can put a SOLD underneath the title
This way you can track the traders through the title which is more then enough information.
I have lost my editing ability's on all my posts.. I used to be able to edit any of my post, this morning that has stopped and can only edit my last post..does it have a time limit on it?
Instead of being able to edit I have to delete and start again..
Is there something new being trialed?
Ok read Barons post and that's crap that we have to report now if we want a post edited and I reckon puts more work on the already stretch mods and admins, makes it hard for me to edit my first post when organising events, I have the same thread running constantly and just update first post for each new month :D will adapt to the timelimit if that's the new way :)
so far I have only had one person hit report post and use it to edit their post. and I did it straight away. which is surprising given that I am a mod of quite a few sections.
if you have a post you want edited, either to update info, or fix spelling mistakes or whatever reason, simply hit the report post button on your post state what you want changed and the relevant section mod will fix it up. :woot:
i've reported few time on my for sale section but have no responses.. anyway, i'll report it again, just want to get my for sale topic delete as it've sold
cheers
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
