  • Replies 244
Posted Images
Sidd i told you at least 10 times when i was going hahahahaha.
And yes, Japan is fcuking shamazing!!!!!!!!!!! Didn't read the previous page, but a meetup in march would be good/fine with me.
  • 4 weeks later...
Yeah i been back since the end of feb lol. Where have you been? Did you go away. I got your out of office reply, i assume your back at work today?
I say we do this next weekend perhaps or something like that?
ah yea i knew you were back.. just saying so we gonna do a meetup or what.
Yea see whos keen etc. Hopefully weather will be good!!
Back at work now. Was away for 2 weeks at a wedding overseas.
Edited by siddr20
Well seeing as its basically April, how about sometime in April? E.g. the 23rd/24th? That is for those of you who are too lazy to look at a calendar, a saturday and sunday.
Are we going to shoot landscapes and cars? Do you think it would be good to meetup, take some snaps, go for a cruise and get some food?
Suggestions people!
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
