Hey guys, I want to get a GTR to build up, I want it to be a sort of time attack car. I'm just wondering since I will be changing everything from the driveshaft, the engine, seats, doors, boot, bonnet, wheels etc why buy a gtr for like 40k if the chassis is the same in the GT. SO my question really is, is the chassis exactly the same? I mean EXACTLY as in you can put all the GTR parts in if you wanted to without any mods? (Not that I'll do that). Is it made from the same material? I'm asking this because I've found R34 GTs for like 10k, that's dirt cheap and thats not all, I would sell the GT's engine, seats, bonnet, exhaust etc and it would end up as like 7k only. Then I would build it up, I'm pretty sure it's cheaper than buying a GTR and then doing the build. So what do you guys think?
https://www.sau.com.au/forums/topic/341202-gtr-vs-gt-tgtsgt/
Well I suppose it depends if you want an AWD or just RWD.
If you are just after RWD there is nothing wrong with buying a GT/GTt.
Here is a good thread to read http://www.skylinesaustralia.com/forums/R3...ld-t280439.html
The materials with the exception on the front hanging panels are the same.
Major points of difference are bolt-in strengthening in GTR (at B pillar and rear tower notably), and the GTR also has scallops in the front "chassis" rails for front driveshafts.
Firewall also recessed for booster for clutch master.... but not essential for a race car.
Basically, all of it can be got around.
if you don't care about 4wd and are happy with rwd then go the gt-t. will work out a lot cheaper. for the money you save buying the car you could have it modded to be much faster than the gtr. if you were thinking of making a 4wd gt-t with a heap of gtr stuff then just get the gtr to start with.
If it's only for track use, go for the GT/GT-T and spend heaps on Mods.
One of my friend did pretty much the same as you. He built up his GT-T with RB26 in it, etc. for track and spent lots on it. But now, I think he's selling it for $30k+. :D
Edited by Victor.T
I was thinking about 4WD but I guess 2WD isn't so bad, the thing is I could buy a GTR but this idea just hit me that maybe this is cheaper. If there's welding and stuff to get it close to the GTR then I guess I'll just get a GTR and sell all the unwanted parts like brakes, suspension, seats etc.
Where can I get a high KMs GTR for cheap? There's nothing under $38,000.
They pop-up every now and then. Patience is the key :)
I remember seeing one not too long ago it was $36,000.
There were some on j-spec that were reasonably priced.
The advantage with buying a GTR (if you are thinking AWD) straight out as opposed to a GT4 (non turbo, AWD, only in Auto).
- GTR has the RB26DETT already.
- 6 speed maual trans
- Wider body
- Stronger axels
- Brembo brakes
Basically what I'm trying to say is - in order to build an AWD monster it will cost you much more to build up a GT4 as opposed to a GTR.
The cost of labour during the conversions/custom parts will cost heaps. Even if you decide to sell the GT4 parts you will not get much money in return. There also seems to be more support and bolt on parts for a GTR too.
Fair enough that's a really good assessment. I am willing to pay for a 40k GT-R but since most of the parts like the brakes, suspension etc are getting replaced I'm being patient to find a cheap one. I'm not building the car by myself I've got 2 of my mates in on it so money isn't that tight but getting a cheap one would help save some money plus it'll make the missus happy, she says I'm having a mid life crisis lmao. If anyone knows one for like 34-36k even in high K's I'd much appreciate it.
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
