cylinders 1,3,5 arnt fireing its def a fuel problem cause the spark plugs in cylinders 2,5,6 when u pull them out after having the car runing plugs are wet with fuel and smell like fuel changed my ecu with another rb20 one did the same thing suspect its a wiring probem but have checked the wires seems to be fine :D
check the suspect injectors for continuity.
checked the circut in the injectors that arnt workin to the computure circuts fine changed the the computure over with another rb20det comptuture made no difference changed the cas over with another made no differance :)
Check the injector pins on the ECU with a test light see if the problem is in the loom or at the ecu end, as you tried a different ecu almost certainly the loom somewhere, just keep tracing it until you find the issue, pain in the ass but not much else you can do.
This happened to me a few years ago on my pulsar gtir after I installed a fmic. I accidentally disconnected something but cant remember what its called. it might be a resistor pack or something for the injectors..
Anyway its the silver box thing on the passenger side, under the bonnet just near the top of the suspension turret. its got a plug on it with a few wires coming out of it.
It may not be a resistor pack. But my sr20det definitely had this plug thing that controlled the injectors. The silver part was just a shield that covered the plugs and I think there was 2 of them. I accidentally put tension on the wires with one of the stainless pipes I installed for the fmic which was enough to break the contact on the plug.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
