No longer need this car as my new car has arrived.
Nissan Exa N13 (targa top)
1989 Model
White
5spd Manual
280,XXXk's
Reconditioned engine approx 10,000kms ago
New head gasket, power steering pump & radiator
CD Player w/ ipod cable, alpine type R's in the front and pioneer 6"9's in the rear
Sports exhaust (Comes with standard exhaust)
Momo steering wheel
Pod filter
Recently Serviced (Fluids, spark plugs, oil filter)
Car runs well i use it to get to and from the train station. Gets approx 400km per tank (Around $45 a tank)
History -
Bought this car off a friend while my other car was off the road. Car had a few leaks/squeels but have since been fixed, just needs a new owner.
Pics will be up over the weekend, I don't come on here often. Shoot me a msg 0403262569 to organise a time to test drive.
$2300ono - Quite cheap considering average price on carsales is $3000-$4700 Make an offer and its yours :D
Se Suburbs Melbourne.
https://www.sau.com.au/forums/topic/341212-melb-daily-driver-fs/
if your keen in another exa i have one turbo needs head done 2k has microtech etc. etc.
Can't say I am sorry. Great car to drive day to day but not keen on a heavily modified one. Pics will be up over the weekend. Replied to a few pms msg my phone to organize a time to have a test drive.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
