sorry not real sure which but my car has a hybrid i/c and apexi pod.I thought having a heat shield would prevent hot air from the engine bay, whilst having that extra hole where the standard piping used to be having air directed from there onto the pod.what u reckon or is it pointless
https://www.sau.com.au/forums/topic/34123-heat-shield-ideas/#findComment-685093
  • 10 months later...
  • 3 months later...
This is how the heat sheild was set up on my last R33 it also had a cold air intake from underneath the front wheel/spoiler and was very effective as you all know how much heat the engine bay produces, im currently making a new one for my new car due to the intercooler pipes being in a different place etc...
The easiest way to get one would be to make it yourself since most cars have a different set up. Its quite easy as im making my second one as we speak.
1.ust take a cut out of cardboard and put it roughly where you want it.
2.Mark all the areas where the pipes are and anything else that is in the way.
3.Cut them out and check it again cutting and shaping it as you go.
4.You can also put bends etc... in the cardboard and tabs etc.. for bolts and so on.
5.Now you have a template, just take it and cut it out of what ever you like(i used 3mm polished alliminium), then bend it up and presto.
It may not fit perfect first time but if you have a real good stencil it should work pretty well.
I also added a little bend to mine to make it look factory.
Cheers hope this helps and if anyone else has some good idea's then lets hear them.
2 ingredients needed for cold air intake.
100-130mm PVC elbow.
Angle grinder.
As was said above u need to make a shield for the barrier, which can be done with some cardboard for template and some aluminium sheeting. Then cut a hole in front left wheel arch and it will be able to sit right behind the bumper. DO NOT CUT STRUCTURAL STEEL, bad plan, minor cutting only.
Or you could buy one that is made for it :P
Your other option is to find some good vacuum hose and mover the whole filter down into the bumper but that might get a little wet on rainy days. You willl still need some sheilding though.
asylum, i uses heat shield, i got a shit load from clark-rubber, they have two types a really think one or just normal, i basicly cut it with a knife and just suck it in there (the car come with like a metal plate which goes over the top),
If you dont have a fmic i have been told it is pointless as there is no direct air-intake as such, basicly your ment to uses the free hole (one which was uses for stock side-mount) and get a PVC pipe and direct the air in through the hole
man i bought one for $150.... i will c if i can find the guys car.... (paul (gtst vspec) its the guy that u gave me the car 4) he lives near bunbry...... they sell his ones at extreme machines for like $700... which is bs....
they are made of aluminium...... side and the top of hte box is also aluminium..... for those that are looking they are for the r33 only but
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
