hey guys got a really bad shudder in my rs4 drive line shudders under any sort of load any one point me in the direction of any good drive line mechanics to sus this out for me also need cv boots replacing
cheers
Rose
https://www.sau.com.au/forums/topic/341244-driveline-shudder/
Any kind of mechanic would be good to suss out the problem really.
Possibly a loose bolt, twisted tailshaft, i guess once they are under there, they will know.
Adelaide CV Joint and Mechanical Repairs in Para Hills?
RS4 with the front shaft still in?
Do you have different sized rims or tyres front to rear?
The AWD Stagea requires same diameter/circumference in wheels and tyres combo. If they're not the same, then your altessa system is complaining about it.
  • 3 weeks later...
cheers
Rose
I get same issue in my rs4 from time to time. under acceleration some times, bit of a shutter! havent had chance to have a look at it yet! Do have 17x8's on front and 17x9's on rear? no idea if that has anything to do with it! but dont see how having wider wheels would cause a shudder???????
shudder is 99% one of these ..... overheated/worn/bent /oily clutch, worn u-joints/ cv joints or too much lash in tranny or axle , or carrier bearings on drive shafts, (sometimes really worn bushes create shudder feel but rare unless tranny mount or engine mount is broken)easy to suss once the car is jacked up.
could be a combination of a few of the above items,
mine is getting bad, but clutch is worn out....lol annoying for sure
yeah i get that but how can it cause a shudder?
If you have different tyre sizes the transfer case has to slip to make up the difference.
In the R33 and later 4wds there is preload on the clutch inside the transfer case so it doesn't run free like the r32 4wds do. This is why you can not safely just pull a fuse and drive in 2wd with anything later than a R32.
The reason this causes shudder is because the clutches in the transfer case grip until the load between front and rear builds and then slips. This happens over and over very quickly causing a shudder. It can happen anytime, whether under load or not, it just depends at what point the clutch wants to grip/slip.
The shudder can also be caused by air in the system, get it bled out by your mechanic
My car has a shudder under mild load and is caused by air from a leaky bleeder and gasket, it is on the list of things to get fixed.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
