hey guys i have a 1996 nissan skyine gtr v-spec everthing must go.
front guards, includes GT badges and blinkers - $500 pair
S2 headlights - $300
sideskirts + rear pods - $200
Guard liner plastics, both sides - $100
Brake vent plastics - $100
pairTail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
afms - $200
pairStock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
A/c condenser - $150
radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
R33 GTR front + rear seats + door trim, complete set - $1200 ono, will probably seperate
If you're after any random bits and pieces that arent listed p.m me or contact me on
(0413134211)
https://www.sau.com.au/forums/topic/341255-wrecking-r33-gtr/
hey guys i still have bonet and guadsr and headlights and doors and gearbox
and interiour make me a offer for what u need and since im selling everthing cheap.
i stil have more parts if i forgot to mention something let me know what u need.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
