black 1993.. ezno steering wheel pioneer DVD player 3inch sposrt exhaust blue wheel nut's blue interior look the good's sell 4 $5000 o.n.o ph: 04 34 25 70 54 non turbo good 4 p's here a link 2 pic of the car http://www.skylinesaustralia.com/forums/Ph...image77963.html
https://www.sau.com.au/forums/topic/341333-black-r33/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
