Just a quick question for user/previous user of Kumho KU31 tires..
What tire width did you have, power level of your line and whether it held second gear or not?
Trying to determine whether they'll be suitable for my skyline.. i can only mount a max 235 tire on my wheels and am wondering if a 235 KU31 will hold my 2nd gear (250rwkw).
Currently using marangoni mythos and my second just kills these tires.
Cheers guys!
(I would get KU36 but australia is out of stock till new year for my size sigh).
https://www.sau.com.au/forums/topic/341344-question-for-ku31-users-kumho/
Cheers guys!
I have 240rwkw with Kumho KU31s in 265/35/18 and they hold pretty well in second gear. Need flat road to get the power down, if its super bumped it churps along as it bounces.
You need to have the front wheels pointed in a straight line though when flooring it in second gear, otherwise get ready for opposite lock time :)
Pretty sure that will happen with any tyres bar semi slicks though.......
depends on your suspension....
dont forget federal 595 rsr's
and if you are set up well enough 595'ss's might do the trick
nitto NT05's are better than KU36's and still available... allbeit more expensive
Sussy is hks springs f/r and bilstein shockies valved +25%.
I realised the wheels can just squeeze a 245 on so managed to get some 245/45/17 ku36's put on today. Need to get a proper wheel alignment with toe/camber/caster during the week.
I had a look at the Nittos but couldn't see who sold them ? And on the Nitto website it seems the nt-05 are discontinued.
o0o o0o, i will try these next, cheers.
Where do you get yours from if you don't mind ?
I'm liking the ku36s, just the short drive home and to me, they're way ahead of rt615s i've had before (albeit on a different car).
tyrepower hawthorne.... but that's vic...
fwiw, on petrol i have 285rwkw and drift spec suspension, and they hold it right up to redline
on e85 with 325rwkw i break traction, but only in the very top of second
(235/40/18)
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
