Gday guys i have had a look around trying to find my answer but i haven't found much that helps. Are Auto RB25DET computer and or loom different to manual computer/loom? As I'm trying to wire in my 25 into the coupe and the wire colours are different to what it's telling me. If they are different can someone please point me in the direction of a pin out diagram for both as well as ecu wire colours.
Thanks and sorry if this has been covered before.
Edited by KDS_HR31
Computer is different - doesn't matter if being used in a manual
The looms ... Hmm knowing Nissan it would be the same in theory as usually its one loom suits all.
But I could be wrong there on that one.
Ahh ok thanks mate.
Anyone got any pin out diagrams or know that the loom that goes to the ecu is different? Also its a s2 motor if that makes any difference or helps anyone.
Edited by KDS_HR31
  • 6 months later...
The pinouts for R33 and R32 are very similar. (R32 doesn't have boost solenoid - pin is used for something else). Should be able to find any pinouts you want fairly quickly on Google - some have colour codes for wires as well.
Yeah ECU is the same and the loom is a little different but still works. The only thing you have to change is the wiring going to the gearbox but if you can get a piece of the manual wiring loom for the gearbox you can simply unplug the auto one from near the fuse box and plug the manual one in and all will be good.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
