Now Wrecking Hr31 Passage All Parts Available
WRECKING s3 hr31 passage all parts available (hit me up with the parts you need)
Manual conversion, rb20 5speed gearbox and gear shifter, clutch(ok condition) manual brake and clutch peddles, master and slave cylinders, manual 2 pice tail shaft, gearbox cross member, (only thing it wont come with is manual ecu but can still be driven with a auto ecu) - $600 neg
Hr31 front struts, hr31 discs and breaks, lowered springs (not sure what brand), strut inserts (unsure of condition or brand), all nuts and bolts will be there to bolt up. - $400? NEG
ALSO HAVE FOR SALE: RB30ET COMPLETE TURBO SET UP
RB30eT turbo set up ready to bolt onto YOUR RB30e
standard turbo on low mount manifold.
dump pipe, oil/water lines, all bolts (you will have to use your own manifold stud bolts).
r32 side mounted intercooler and all pipes to connect.
injectors and fuel rail
standard turbo ecu
standard manifold plenum and all pipes
and anything else that is there laying around to go with
Its in great working condition no issues at all :(
can also supply 3"inch zorst to suit a r31 for a little extra
pick up from chermside or can courier interstate at your cost
asking $77777700
may swap for parts of interest pm me
can also get more close up pic's if needed or come take a look for ya self
ALSO HAVE: 3" inch exhaust system from dump pipe to tip come off a hr31 passage (can send pics just ask) $220
AND HAVE SOME>>> RB25DET S2 R33 ENGINE PARTS:
1 x S2 Rb25det ECU $230 (can supply with full complete engine wiring loom) both in great condition
6 x S2 rb25det injectors, fuel rail, plugs & loom $250 great condition
2 x S2 rb25det AFM air flow meter (pink label) $150 each great condition
1 x rb25det stock air intake plenum comes with throttle body $180 great condition
1 x rb20det or rb25det CAS (crank angle sensor) $50 great condition
1 x rb20det/rb25det manual gear shifter $70 good condition
1 x 3" inch universal intercooler piping kit complete (brand new) $270
Package included:
2 x 18" straight pipes
2 x 19" 45 degree pipes
2 x 17" 90 degree pipes
2 x 18" 75 degree pipes
16 x clamps
8 x Couplers (Color - blue)
CAN USE AUST POST OR COURIER MOST ITEMS (AT YOUR COST)
I'M LOCATED IN CHERMSIDE (BRISBANE NORTH SIDE) PICK UP FROM THERE
CHEERS LUKE
i might be keen, but im a bit far away lol.
I'll see if I can find someone to pick it up depending on how much you were after for it.
No promises though.
scrap metal yard is giving me $400 with the f**ked engine
so save me the hassle for taking it there you can have it for $300 with the engine?
 Share
    • Glad that worked out for you. I think my Joyeauto one is coming this week but I won't get to install it til closer to end of October. Will update when I get around to it. Just standard CP and nothing else. Hopefully the cameras all work without needing to get out of CP and get back in as they advertised. My other worry is sound quality. Fingers crossed!
    • Yeah, it is possible. But like many related things (ie, alternators), it's getting harder to find anyone who does and will, given the change to just throwing shit away and replacing with new cheap shit from Chinese factories. If you want to pursue the option of rebuilding, you'll have to dig up an auto A/C specialist or three to find out whether they still do.
    • There are a few, but not that many. Also, there are no such rules when it comes to importing, just taxes and paperwork in general. The only rule I can think of is excise tax, which is 3.1% for cars with an engine under 2 liters and 18.6% over. About mods coming to the car, I've already bought Tein Flex Z coilovers and TE37s S Plus in diamond dark gunmetal (front 8.5" x 18" +35, rear 9.5" x 18" +22). Rims will be here in March. When the car arrives, I'll probably do a custom turboback and some exterior mods. I will keep you updated on my progress here! :)
    • Rb26 has gone in to a gt 4 r34 model
    • Hi can anyone shed some light, pin 104 and 106 from rb26 ecu is not connected is this important? If so will i need the fpcm and wire this in?    car runs but lumpy and sparks plugs getting really black soot on them. Fueling issues by looks of it have t attached these 2 wires as dont know where it goes?
