As the title says my window is stupid well last night it went down but now it aint goin back up i have an r33 gtst i am just wonding were i could get a new electric window motor from i am in melbourne and how much would one ruffly be thanks for ya help
https://www.sau.com.au/forums/topic/34142-stupid-window/
The problem may not be the motor. Is it your passenger window?
Sometimes the job is as simple as pulling both driver and passenger switches out, pulling them apart and cleaning the crap that builds up on the contacts.
If you are not 100% sure that your motor is stuffed, try cleaning the switches - it may save you some $$$.
https://www.sau.com.au/forums/topic/34142-stupid-window/#findComment-684914
i been fixing a few of these laterly. whichc door is it?
check the black box in the drivers side with someone elses. and see if it works, if so, look in the black box and see if its just solder ****ed up or a capasitor shit itself, you can get those black boxes for abou $70.
if not then check your motor. sometimes the spline in the motor is worn or slips down abit.
http://forums.skylinesdownunder.co.nz/show...&threadid=17097
have a look there.
https://www.sau.com.au/forums/topic/34142-stupid-window/#findComment-685562
have a look there. or
Posted by: sherlock_nzl
To remove window motor
Get a length of masking tape and run strip along joining window to door.
Remove door trim
Disconnect wiring
Remove 3 screws holding motor assembly, the 4th screw needs only loosening in its slot then lifting up and the head of bolt will pass through hole.
Towards rear of door there is 2 bolts 150mm apart in vertical slots with marking next to them, with scriber, mark ring around bolt/washer (so you know where to put it on reassembly) remove bolts.
At bottom of window glass is a rail with a bolt at each end, undo nuts and at same time watch the end of the bolt to ensure it does not turn, if it turns hold the other end which I think is like a flat washer with a couple of flats on it. (You may have to undo the masking tape and lower the window down to get to these two bolts) after you have removed these two nuts and pulled off rail, move the window to the top and retape.
Motor and arms can be removed through the large hole at rear bottom of door.
Refer to other reply for motor repair.
https://www.sau.com.au/forums/topic/34142-stupid-window/#findComment-685564
  • 8 months later...
To bring up an old, but helpful thread.
My car had been sitting for just under 3 months, the drivers side window went down but it never came back up again.
I just pulled the door apart to find the motor was rooted. It was clicking, just no movement. So I do what you do to all electric motors that don't want to work. you hit it, and you hit it HARD!
Problem solved.
If you've ever owned an old car and had the starter motor not work, you'll know what i mean :D
Shaun
https://www.sau.com.au/forums/topic/34142-stupid-window/#findComment-1083044
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
