Although looking at that dyno sheet, seems pretty decent tbh. AFR's look good (well, they're rich lol...but about the same as mine :))
Yeh I have no knowledge how the AFR's should be, thus why posted it for comments. Things can be retuned a bit later any way. The car was smooth, and neat, the power was consistent and with 10" of rubber on the rears it held neatly (I have the stocks rims at home now though - the fronts of the rims on the car are a bit scrubbed on the inside, needs a good alignment and balance done).
odd the way it falls over at 150kph?
By the look of it, it isn't just a mine's ecu. It looks like a custom tune for the setup (AFR's anyway)
I thought that would just be where it isn't peaking more power, and decreases... It has to happen somewhere right?.... I'm not all that sure why...
(not like I need the power over 150kmh myself as I'll only be driving on streets...)
I'd say the car has been custom tuned, it was well loved and looked after, driven fairly minimally and appears to have no issues that I could find - however to be safe having the mechanical look over, compression test and rego check being performed before more than a deposit is laid down.
Edited by J'son
wrong.
first chance you get you need to take it to wakefield...
also bring it up to the NSW Texikhana next month. good sexy fun times
wrong.
Hahaha
And then you will want to strip it, cage it and stick a 600hp 3L in the thing with a dog box bolted behind it.
Well thats what I did
Haha, yeah thanks guys - I may someday, but prob not ever gonna race it.
I love the power it has, but love the look and the feel of the car too. I wanna look after it well and keep it lasting me a while.
It's also gonna be my daily driver. Admittedly I work 10mins from home, and don't gotta travel far round town normally, but I intend to keep this baby for a good few years.
Sorry yeah you did answer my Q. I meant more what is the deal with solving the issue.
Kinda sux cos means speedo's top out, even my current pulsar reads up past 200.. And has done so.
national speed limit in jap land??
And there goes any respect I had :down:
Well for starters this whole site (admins, mods, execs etc) Do not want the club to be seen as a bunch of hoon street racers, who do 200km/h on public roads.
Considering the fact that just about every news program/newspaper/police agency have accounts on here and are always trolling around looking for stuff to pin on us.
Its not a good idea to be saying that shite
I never once said I did that on public roads. That's just stupid and irresponsible.
Not like I need the power over 150kmh myself as I'll only be driving on streets...
Edited by J'son
Getting the car tonight. Compression check, spot on. Rego check - PASS!
I put the stock rims on, and all was fine.
Number plate lights are out, and so is the wing light, but it was passed - just was told to fix those - as they are things I'd get booked for if drove it like that.
So now can somebody tell me how to fix/replace the lights for the wing...?
Where did you take it???
That's awesome news mate, good to hear!
Absolutely no idea about the wing light to be honest...could try buying one from a wreck or something...otherwise go to Nissan spares or something for lulz and see how much they want.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
