I never once said I did that on public roads. That's just stupid and irresponsible.
Just how I read it :)
Getting the car tonight. Compression check, spot on. Rego check - PASS!
I put the stock rims on, and all was fine.
Number plate lights are out, and so is the wing light, but it was passed - just was told to fix those - as they are things I'd get booked for if drove it like that.
So now can somebody tell me how to fix/replace the lights for the wing...?
The wing lights are LED's yeah?
EDIT: Ok pending pass, i gotta fix numberplate lights and wing light.
It may just we wiring. I'll get somebody I know to take a look monday.
Simple enough fixes.
Took it to : Premier Automotive Repairs, 5 Winchcombe Lane, Mitchell - 62428450
Great guys there. They replaced one of my wheel studs that was stripped on my Pulsar also.
NP, I don't want to be thought of as a fool or irresponsible or get myself banned for something coming across wrong.
yeah I think so... might just be wiring, not at all sure.. Just gotta take a look and fiddle and see if can sort em out, asap. Least those fixes won't cost me a fortune.
Oh they did note "Advise: exhaust height at 100mm". Rear exhaust as it curves under the rear axle it sits at at 100mm, long as as I don't put to fat bastards in the back it's all good. Plus the suspension is stiff enough any way.
nononononono, wherever I went Andrew, it was about as close to the DIY car wash in Lanyon as you can get...
That's the place.
Thats what i thought the 1st time, google lied to me the bastards lol, its good but, like 2mins from my house :)
Hey, can you guys help me better understand the differences between S1, S2 and S1.5 cos this is a S1.5 and has elements of both together. I read the thread on the differences between S1 and S2, but still bit lost.
I think I read somewhere that s1.5 was just s1 with factory options that s2 came standard with, like ABS and airbags....I'll let someone clarify though
Edited by Trozzle
ah fair enough.
More or less, no difference. Coils are old enough that their original quality is negligible as they're probably about to fail anyway. CAS probably wouldn't make much difference if any. Turbo....well, same sorta deal as the coils - but if my series 1 turbo is anything to compare to, you won't have any worries running it at 11psi all day every day, which is just shy of hitting R&R anyway.
Thing is, this one has the S1 front grill, and lights, S2 rear lights etc, but S1 Grey bar with SKYLINE on the back.
Thats all I really knew for sure.
It has NO abs nor does it have either drivers or passengers airbags.
Not sure if actually is S2 engine or not (turbo, coils etc)..
I have one pending problem that discovered this arvo when collected the car back from the mechanics... They'd not hooked something back right and now it's misfiring.. So gotta take it back and make em fix it in the morning... Damn bastards. This is why I don't like going to mechanics.
We had a really good look and can't find anything, so gonna have to get em to strip it back to the plugs like did today for the compression check, and they better have it sorted for me. I'm so pissed off.
Edited by J'son
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
