Yeah cool cool. But curious about if really is worth spending the $50-59 bucks on the 5L for some those brands vs, things like Castrol and Shell etc that can buy from Auto Barn, Super Cheap etc... I want to be changing the oil every 3months of 5000kms, and $80 each time whilst doing all the work myself still feels a little steep...
I used to run Castrol Edge 5w30 in my SR20DE, and that worked really well, but last couple changes went to Castrol Magnetic 10w40 cos the engine was starting to get a bit more rattly with its age.
it will be worth it mate, it isn't THAT much extra for a much better oil.
Yeah, fair enough call
$20 for genuine filter vs $13 for a ryco.
$59 for the oil vs $40.
I guess the $26 bucks extra for quality and upkeep of such an awesome vehicle is worth it.
filter - just use ryco imo.
In the other thread was saying the genuine ones are meant to be better quality than the ryco ones, but not sure how or if is really true.. But is convenient to get them both together at the same time..
Headlights installed. Boost gauge fixed (not perfectly, and not properly, but on a way that seems to be working successfully....) - should fix it properly later.
Any one able to advise on where the clutch adjustments are on the skylines? I wanna make it start engage closer to the floor like I did in my previous car - if possible.
Almost certain. Well, certainly not worn as much as my pedal movement would suggest.
Autotech advised me after having my car there once that the clutch pedal was adjusted right out, and that they put it back where it should be. It has since found it's way back to where it was pre-adjustment
On my Pulsar all I had to do was find the arm that attaches to the gear box, where the clutch cable attaches, and tighten it (shorten the cable - lock nut + adjuster nut), then adjust the nut behind the pedal in the car to take away the slack that has now been created.
I'll look more carefully at home, and see if can find it.
this is potentially a very dumb comment on my part, but I was under the impression this was a hydraulic clutch in the skyline lol
Which I do not know, and that may be totally correct, this is why I was asking :D
They can be adjusted, but are done differently and I have NFI...
yeah I'm 99% sure it's hydraulic...the adjustment would be on the master cylinder part of the system, probably above the pedal inside the cabin...I'm gonna have a looky at mine this arvo
Yeh confirmed was hydraulic. And thats fine. Now gotta see how the adjustments work, and have a go at fixing it without rooting it. *fingers crossed*
Clutch adusting mission a complete sucess.. It was a bit of a pain in the arse, and had to use pliars to help, but got there.
There is possibly a little too much free play at the top end now, but couldn't adjust it more.. and I'm not positive what the sensors all do on each pedal, but I believe it still depressing it correctly. I'll check again tomorrow.
New headlights look awesome. However the issue with my boost gauge is a bit odd, but prob just needs a new tube.
Well after hanging my head down in the footwell for a good 5 minutes, I can see exactly how all the adjustments work....
From the looks of things, you can adjust the piston (our main concern), the throw as I'll call it (how far down you can push it), and the release (how far back it will come)
I'll be spending some time adjusting mine tomorrow arvo or Saturday morning.
I think I got mine pretty damn good, minimal movement in general, but the adjuster at the top for the pedal position is now maxed out - had to make sure the little sensor button still presses. But It was a pain cos had to use long nose pliars to turn the MC shaft, but it worked in the end. I'm happy. Now just gotta get used to it - again.
Let me know how urs goes.
Edited by J'son
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
