HEY GUYS,
HAVE AN IPHONE 4G 32GB FOR SALE.
WORK AT A PHONE STORE AND WON THIS AT A COMPETITION.
HANDSET IS BRAND NEW AND SEALED. NEVER BEEN OPENED.
WILL PROVIDE HANDSET UNLOCKING CODE TO WHOEVER BUYS THE HANDSET IF THEY WOULD LIKE.
YOU GUYS ALL KNOW WHAT IT LOOKS LIKE.
BUT BE REST ASSURED IT IS BRAND NEW AND STILL IN THE WRAPPING AROUND THE BOX.
ASKING FOR $799 BUT OPEN TO OFFERS.
WILL SHIP AT BUYERS EXPENSE
THANKS GUYS
https://www.sau.com.au/forums/topic/341477-iphone-4g-32gb/
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
