  • Replies 41
Guys this is usually attributed to the transfercase to front diff tailshaft. Pull it out and you will notice that as you turn the uni joints around manually they will be quite notchy. The other usual cause for this is the front CV joints needing the grease to be removed and repacked. But I'd be pulling the front tail shaft out first and feeling if the uni's move without any notchy spots. My bet is it will be! Seen atleast 4 like that now including my own.. replace the shaft.. all good.
OSF TRACK ROD END WORN BUT NOT SURE IF IS THE PROBLEM , WAS STARTING TO THINK ABOUT SOME SORT OF BUSH SOMEWHERE IN THE DRIVE-TRAIN MOUNTING , WILL CHANGE TRACK ROD END FRIDAY AND SEE
Caps lock off please :P
can the joints be replaced or do you need to replace the whole shaft!
Welcome back to the forums mat! Hope your ready for some fishing this summer, I'm inquiring into buying a tinny tomorrow. Look out all garfish in the bay! Haha
And to ben, the shaft isnt that hard to drop out, I somehow can get a socket on one end and ring spanner on the other... Intact I can often crack them by just using the socket end sure they spin a few times before they bite and un-do but it does happen eventually. They don't need to be ball breaker tight either. Got a spare shaft you can try here to ben if your joints are suspect not sure how good the joints of my spare are but you could use it to eliminate issues :-)
I've also noticed I am starting to get this slight shuddering under hard acceleration ...happens from about 50-90 km/hr.
Also have a slight noise, much more pronounced when turning out of corners but related to heavy throttle and heavy engine load only...doesn't do it at idle or when engine is revved at idle. Kind of sounds like a wheel bearing noise but not the wheel bearings...CV's ? driveshaft uni's? accessory pulley? water pump? Related to above problem or seperate?
I call it the 'Stagea Strange Noise' (SSN) and keep driving.
Well been chasing this same vibration problem now for a couple of weeks so far replaced front cv joints, wheel alignment, then today replaced front drive shaft from transfer case (with a GTR one) coz removed old one and def felt notchy and guess what still getting vibration :) ???????? what next rear drive shaft any one had trouble with these seems to bo a cv joint in them as well as uni joints
cheers
rose
yeah new wheels on there all balanced also had two other sets on there all did it as well :)
If the problem is not sorted by the time of the Stagea cruise I'll jump in the car with you and see if I can diagnose it for you.
Well the bolts were effing tight and I'll end up replacing all the nuts - 2 of them got burred. But, the sucker is out, and the uni's _are_ knackered.
I'll be dropping the shaft into Adelaide Tailshaft Services ASAP to get the uni's replaced. A new shaft is $1100 (special price) from Nissan...
I test drove the car last night, and the vibration under hard throttle seems to be fixed (but the traction is certainly reduced. For those that have wondered - the ATTESA-ETS is used LOTS, even in everyday driving). However, my wife has indicated that a vibration at ~100km/h is still there. Its nature is consistent of wheel balance issue (rotation movement in the steering wheel), so I'll be getting that seen to this weekend (which is almost due anyway), but will check the CV's for play between now & then.
Really not a fan of auto gearboxes and so i dont know enough to be able to know, but is clutch shudder possible with an auto?
Edit: Didnt see the second page, seems to have been resolved lol
How do u pull out your front uni, theres four bolts toward the front of the car which will detach the front end. Does the back end simply pull out, if it does is there going to be any oil/fluid come out or is it like a dry spline.
  • 1 month later...
well i still have this persistant little problem of the shudders all uni and CV joints replaced new front drive shaft in big improvments, but looks like problem has been located while having the car up on the hoist to fit auto shift kit in had a good look around and the rear drive shaft center bearing looks deteriated giving the drive shaft some play especially when the drive line has warmed up so looks like replacement time hard part is have to take it out so can take it to some one so they can match new one up unless any one on here knows part number for one. But the MV automatics shit kit is excellent best improvment yet :wub: chirps in to second
Edited by 4bidn1
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
