Reason for Selling: Want something that isnt as nice for drift practice lol.
Asking Price: 15000
Delivery Methods: PickUp
Contact Info: PM me, will give mobile to serious buyers.
Extra Information:
97 R33 SKYLINE M-SPEC SERIES 2 - 40TH ANN EDITION
94000KLMS
RB25DET MANUAL
ARCTIC WHITE
JDM JISMO WINDSCREEN BANNER LOL
15% DARK TINT
SERIES 2 FRONT BAR
URAS TYPE 2 SIDESKIRTS
GTR REAR APRONS
NISMO CLEAR SIDE INDICATORS
DAMPER ADJUSTABLE KYB LOWERED SHOCKS AND SPRINGS
SLOTTED REAR BRAKE ROTORS
18INCH STARCORPS, 8.5 INCH FRONT, 9.5 INCH REAR
30MM AND 10MM SPACERS
ROLLED FRONT GAURDS
STRETCHED 225s FRONT, STRETCHED 235s REAR
FRONT MOUNT INTERCOOLER
DRIFT BOV
POD FILTER
JUN STRUT BRACE
D1 SPEC OIL CATCH CAN
FULL TRUST 3.5INCH EXHAUST
BOSCH 040 FUEL PUMP
ADJUSTABLE MALPASSI FUEL PRESSURE REG
EXCEEDY HEAVY DUTY CLUTCH
TOLMI 2 WAY DIFFERENTIAL
REMAPPED ECU
NISMO SHORT SHIFTER
PIONEER HEADUNIT
KENWOOD SPLITS FRONT
ROCKFORD FOSGATE 6INCH REARS
KENWOOD 1000W MONOBLOCK CLASS D AMP
PIONEER 12INCH 1000W SUB IN BOX
BLUE LED SPECO BOOST GAUGE
APEXI TURBO TIMER
BLUE LED DASH
BLUE LED CLIMATE SCREEN
BLUE LED CLOCK
BLUE LED PWR WINDOW BUTTON
BLUE LED FACTORY ROOF AND BOOT CURTESY LIGHTS
ALLOY GEER KNOB
FULL SET OF S2 MESH STYLE R33 FLOORMATS
Very well looked after grade 5 import,only 94000klms,extremely reliable but with decent power.I dont have dyno sheets but i'm told is making around 300rwhp. Only running 9-10psi with no boost controller.
Completely unmarked interior,body and paint in great condition,engine bay is spotless,carpet is spotless.
After a swap for something cheaper like an S13, 180, R32 and cash my way. Would also be interested in a Ninja 250 and cash
Comes with 6 months rego,rwc.
  • 4 months later...
Bump, NOW HAS A HICAS LOCK OUT BAR, NEW REAR TYRES, NEW TIE ROD ENDS, AND HAD IT ON THE DYNO, MADE 263HP AT THE TREADS ON 12PSI HAVE THE DYNO SHEET TO PROVE. SELL OR SWAP, SHOW ME WHAT YOU GOT.
  • 1 month later...
  • 2 months later...
  • 3 weeks later...
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
