I heard that Single Turbo Supras are pretty wild. Do they mod a N/A engine, or do they mod a twin turbo engine to get these single turbo supras.
I deal suituation, 6speed N/A SZ-R Supra (1993ish) with 1 big turbo.
Anyone know any information on this?
Cheers
(if I have posted this in the wrong thread, feel free to move)
https://www.sau.com.au/forums/topic/34152-question-on-single-turbo-supras/
Turbocharging a SZ is both a waste of money .. and won't give you the required results unless big bucks are spent. The TT engine is a monster internally, and quite different. You can pick up a TT Supra for under $30k these days, and the NA are often around $20k. To turbo the N/A will cost you probably more than $10k, and it won't be done that well. Its similar to turbocharging a GTS n/a skyline. Can be done, but do you want to bother?
My friend investigated it (and to him money wasn't even really an option), ended up selling the SZ and buying a GTR :) Smart
DJ984 - The twin sequentials use one small and one larger turbo. The smaller one does not have a wastegate and it runs out of puff somwere in the rev range (not sure were) and this is were the bigger one is already workin to take over. Very heavy and tricky setup so big single on a 3 litre which will support 500+ HP on stock internals is usually the path taken.
Cheers
ok, fair enough... so they're both driven of 3 cylinders each?... (like a gtr set-up) it's just that one's small and the other's big in-order to have the best of both worlds (quick "off-the-mark" accelleration + top end power and speed)???
SZ = was the NA
GZ = TT with leather seats, cruise, active spoliers
RZ = TT with cloth seats, airbags and sometimes an active spoiler
RZ-S = was a TT with electric seats but none of the other toys
are you sure its a SZ-R and not a RZ-S? It's very expensive to turbo the 2jzge motor.
The cylinder head, camshafts, intake manifolds, and exhaust manifolds are completely different between the GTE and GE engines.
The intake manifolds are also completely different in design, and again the GTE versions will not fit directly on the GE cylinder head.
The GE engine was fitted with a distributor ignition system, while the GTE engine was fitted with the latest high output coil-on-plug ignition system.
As easy as it would be for the aftermarket, the factory Twin Turbo system from the GTE engine will not fit on the GE as the bolt patterns are completely different.
The Non Turbo Supra received two transmission choices, the four-speed A340 automatic and the five-speed W58 manual. Both can handle mild transmission upgrades in power to about 400 RWHP before problems begin to surface. ( hmm yours is a 6sp )
But then ive read
1996 - the 6 Speed manual transmission in the turbo model was dropped due to emmision regulations. ( so it is possible to have a 6spd before 1996 )
but then
1997 - Return of the six-speed manual transmission.
  • 8 months later...
  • 5 months later...
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
