Hi guys, i own an automatic r33 gtst s2.
My friend and i serviced the car the other day, new spark plugs, oil change, oil filter, fuel filter, and now im having issues with the car!!
Now when i go to drive it there is like a long pause before it will engage the gears.
I disconnected the battery and reset the ecu/remapped twice and it helped very slightly.
I go to accelerate now and the revs go up and then after too long a pause it engages the power sort of abruptly. Im not sure what i did wrong... dangerous when i need to get on a roundabout!!
Ok one thing i had noticed i put too much oil in... ive been trying to drain it out but it wont come out!! The sump will give me about a litre then just stop. So i tried again the other day, gave me like 500ml then just stopped completely. I think i still have about a litre too much in there... shouldnt the oil be draining like fairly easily??
any ideas?? thanks in advance
Alex :P
are you talking about the engine oil being too full? if so, just remove the oil cap, drop the sump bolt out and drain it all out and then refill it.
don't see how this could really affect the gearbox though. resetting the ecu shouldn't also have much affect either as it is more than likely something to do with the gearbox oil or the stall converter as to why it takes a while to go into gear.
Alex :P
This doesnt sound good..Id say either some sort of sludge build up is blocking the hole..which isnt good..or did you take your filler cap off when u tried to drain it, maybe its just a vacumn lock but ive never had that happen before..
How much oil did you drain out before you put more in, cause if its not not draining now it probably didnt drain properly before you put new oil in, how much did you put in...
thanx for replies guys,
i didnt remove the oil cap the second time i went to drain oil, prolly why not much came out. When i drained it when we did the service i think maybe 2 and a bit L came out, and i prolly put like almost 4 back in stupid me not realising till i checked the dipstick it was way over. Anyway i did drain like another litre and a half back out but still got a bit to go. Ill prolly put it on a slight incline and try to drain the whole lot then tip it back in like you said.
But yeah the time before this i put standard copper plugs in with 1.1 gap (i used to run .8) and every time i put my foot down the car shat itself, misfiring etc etc so i reset ecu, remapped the timing and it went ok, not great tho. Now with the latest service i went back to 0.8 gap (bcpr6es) and took it for a drive before reseting the ecu and thats when i was having all these issues with the accelerating. I put my foot down, rev meter goes up and nothign happens then suddenly BAM the gear drops in/power engages and it goes - after that initial pause of like 2-3 seconds??! So i reset the ecu / timing and remaped it to the new plugs, but it still does it. Not as bad as before i remapped it (you couldnt even drive it then - too dangerous) but its still doing it to a lesser degree. I go to accelerate and the gear takes its time to engage or the power takes its time to kick in one or the other im not sure which or why!! But now theres maybe a 1-2 second delay. Before all this it would engage almost instantly.
Im not sure where to start lol, should i buy new plugs and start over??
  • 2 years later...
Guys, I'm having the same problem as well. My car seem hesitant as well. The 2-3 seconds lag is worrisome. So whats the solution to this?
I figured that there are few possibilities ranging from a blockage in the air filter; weak battery (Not too sure); blockage in the throttle body or worse, transmission problems.
Hey George
Do you have a 2-3 second lag between the time you press the accelerator and the time the gearbox kicks into gear like the OP or do you have a lag from the time you press the accelerator to the time the revs come up. ?
How does the car feel when your sitting still, in your driveway, is it responsive when you free rev it.
I don't see how a problem with your air filter or your throttle body is going to affect your transmission.
What happens after the lag period ? you put ya foot down -- 2-3 seconds lag -- then the car takes off ,, what happens next, does it run fine through the rev range and change gears perfectly after the initial lag ?
    • Nah, new members can't post pics until they reach a certain post count. If I get a chance I'll promote you to full member, if @Prank or someone else doesn't get there first.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
