hey guys
i reset my ecu to try and suss out my bad fuel economy problem yesterday
went for a spin and car ran beautifully. this morning it sounds like a wrx and drives like ass. really hesitant etc
could it be the coils or plugs?
  • Replies 43
Posted Images
hey guys
probably coils mate, but check the easier things first like plugs etc.
okay coils are out
dont have the long tool to get the plugs out though :P
second noob q- how do i tell if my coils are dead?
Look very carefully around the sides of the coils to see if there are any scorch marks or pit holes.
If a couple are like that, it's better to replace the whole set.
You might get a temporary repair or test, by applying a coat of silicone sealant around the outside and wrapping it with electrical (insulation) tape.
alright,i put it all back together and started it. again "brabrabrabrabrabra" but i also noticed a hissing sound
followed it and found out theres a small hole on the plastic hose joint where the throttle body meets the intake pipe
could this be it?>
none of the plugs looked scorched or anything btw
Edited by Mohsen
Sounds like it's not running on 6 cylinders. Coilpacks are actually the easiest for initial diagnosis. Use the following logic to determine which one is problematic...
Have the engine running, one by one pull out each coil pack wiring loom plug...if a cylinder is working it will make the car struggle even more when you pull it's coil pack plug off. If a cylinder is dud then it will make no difference. Once you locate the dud cylinder/s, switch off the engine and switch the coilpacks between a healthy cylinder and a dud...start the engine again and start pulling coilpacks again. If the previously healthy cylinder is now a dud then it was obviously a faulty coilpack, but if dud cylinder is in the same place then you can rule out coilpacks and start looking at plugs, wiring loom, or fuel supply for that particular cylinder.
could this be it?>
yeah this could definitely be the problem. any leaks in the intercooler will cause it to run terrible.
Are the wiring looms stiff/hard/brittle?
i had the same problem with my 32 after my mechanic degreased the motor 2 days later it was like driving a wrx just went through the elimination process with which cylinder it was and found it was a fried coil which i had a spare set anyways
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
