geez you guys must be really strong? on a serious note...is this the rears only steve or the front you wanna swap unsidedown? if its the rears i can help you as itll be a 10 min job.
Haha, yeah. Get to use the muscle.
I think it's just the rear. Those two bolts at rear were a b**** to take off though.
  • Replies 40
Posted Images
Yea bro its jus the rears . That will b awsum if u can help but wen we swap it over the rear will drop too low and then we hav to readjus the shock and spring. Also for it to go the oda way round the bump stop has to be removed. If u cool wid all that and no how to do it then cool odawise il have to get it done sumwere else
umm slightly confused. maybe ill speak to u soon about it. all i know is that i can take the springs in and out easily
im confused too. is it in english? :P
i think he means when you undo the rear shock the arm swings down very low. hint, stick a jack under it or a piece of wood, a brick, whatever will hold it up
anyway, if he removes the spring, it will require the height reset. which he may need assistance with.
Wat i mean is the car did not lower much in the rear and it is set to it maximum. But it didnt lower cuz t was installed upside down once we swap it over it will lower the car too much meanin we will need a height reset. Thus meanin we have to make adjustments to spring and shock. Dats how this coilover is. And we cant instal them the right way untill that rubber isolator is removed. Its like the second pic atm. But need to get it to the first
If you need to make adjustments to spring and shock, you would need to take the coilovers out again with tools we probably won't have. Looks like you might need to take it back to the shop. (Preferably Pedders Cannington if Evolution R is a problem). Also, might be a good idea to do the wheel alignment this time.
Dont take it back to the silly buggers that installed them upside down, its only like 2 or 3 bolts...
Do you still have the C spanners that cane with the kit?
Then take it to a highly recommended wheel alignment specialist.
Steve, don't go back to the idiots that installed it wrong because
1. they had no clue what they were doing in the 1st place
2. they may get aggro that it'll have to be done under warranty and do a 1/2 @ss job at it
take it to a good suspension shop ....i've used malaga suspension and wilkinshaw suspension at Bayswater before and they are pretty good. the rear suspension setup on the v35 is similar to the bmw 3 series so I think they can sort you out.
incorrectly installed suspension can be dangerous mate so take it easy till u get it fixed
gl mate
Thanx guys no dont worry im not stupid. Im taking it to My own mechanic or wilkinson suspension. Yea last tym i took it back to evolution R told him its upside down. He got one of his co workers who apparently races cars for ford racing and he reckons the only way it can go the rite way is if the bump stop is removed which will cause the tyres will hit the guards wen i go over a bump and burst a tyre. I had a massive arguement and drove off angrilly so ders no way il go bak der.
And Victor no u dont have to take out the shock at all we jus use the C spanner as Scooty m35 says.Only need to take out the spring seat assembly and remove that bump stop i dont think thats hard. Then reinvert that spring seat and make neccesary height adjustments to the adjustors on spring and shock.
Edited by CRISP 35
...And Victor no u dont have to take out the shock at all we jus use the C spanner as Scooty m35 says.Only need to take out the spring seat assembly and remove that bump stop i dont think thats hard. Then reinvert that spring seat and make neccesary height adjustments to the adjustors on spring and shock.
Ok. Well, let us know if you need help. I am on holiday next two weeks stuck at home. :)
Edited by Victor.T
i have the tools. and i can do it for him. can only do it on the w/e though. if your not in a rush steve wait for my call and we can do it this sunday.
Great.
At which place can you guys do? I was going to offer my place but my driveway might chew some bits off Steve's V. :blink:
Edited by Victor.T
Thanx guys im in no rush watsoeva. I got advised to leave rear were it is untill i get a camber kit. Cuz once we drop the rear ima have sum serious camber issues. Its a tough one
Hey just wondering for those of you who actually take your car to the track... was there much of a difference in your lap times before and after getting coilovers VS stock?
I need to do something about the camber on the front of my car and was thinking about buying some camber arms so I can dial in some more neg camber such as these Godspeed front camber arms
At the same time however if a set of coilovers make "that" much of a difference and the BC racing ones seem to have camber tops for the front it may be worth getting them. The price for them seems to be around the $1600 mark for a set however im happy enough with the stock suspension at the moment
Edited by 180 wanabe
bang 4 ur buck would be upgraded sway bars first.
Allready done and to tell the truth I dont think they did all that much, car understeered more even with the front on the softest setting caused VDC to go crazy even when I wasent understeering. So I ditched the VDC and bought some track rims with Toyo R888s which made a big difference
thats probably because the rear sway bar affects understeer more than the front.
how did sway bars affect the VDC?? they arent related!
Adding swaybars to your car can increase understeer/oversteer which in turn the will trip off the VDC if it detects that the car is about to oversteer/understeer
Im confused by how the rear swaybar could affect understeer? its linked to the rear of the car.... in my 180sx it was much easier to drift in with a whiteline swaybar set on hard compared to the soft stock one
Yeah, generally a thicker rear sway bar will make the car more prone to oversteer. As it tends to take weight off the inside rear wheel, oversteer or wheelspin (with open centre diff) is the result. Definitely going too far in one direction or the other can raise issues.
    • Rust repairs completed, doors back on! pretty much totally back together running now. All future repairs will be fiddly wiring getting everything back up to road condition.  hasn’t  taken that long considering the condition I got the sub. note my helpers keeping the back seat warm 😂
    • SAU NSW Old Pac Cruise to Newcastle All Japan Day 2025 Sunday 27th July 2025 5:00AM Meeting Berowra Station Commuter Car Park 2 5:15AM Departure Cruise Via Old Pacific Hwy 7:45AM Arrival to Lambton Pool (Regroup) 8:00AM Arrival to Newcastle All Japan Day 2025 Meet Location: Berowra Station Commuter Car Park 2 Stop 1: Lambton Pool (Carpark) Final Destination: McDonald Jones Stadium for Newcastle All Japan Day 2025 Tickets: Newcastle All Japan Day 2025 $20 Per Car Spectators Free PURCHASE TICKETS HERE *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • SAU NSW Attends Machines & Macchiatos Cars and Coffee Sunday 13th July 2025 7:00AM Meeting Davidson Park 7:20AM Departure 7:45AM Arrival at Northern Beaches Christian School Meet Location: Davidson Park Final Destination: Northern Beaches Christian School Machines & Macchiatos Tickets: $10 Per Car $2 Spectators Pay at Gate LIMITED SPACES Register Below to Reserve your Spot. Members Receive Preference REGISTER HERE   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
