Hi,
I am planning on selling these injectors, but before I do, I need confirmation that they are nismo 555cc yellows as I ordered when I bought them. I bought them from sliding performance, is he still a business trader on here??
Numbers on top of injector: 7E24 1001-87091
Please see attached photos.
Thanks in advance, Matt.
look exactly the same as my sard 650s mate but the numbers dont match
If you look at this thread----- http://www.skylinesaustralia.com/forums/In...se-t341065.html ---- the numbers are much the same as hanaldos top feeds.but sard numbers all start with #6 ..they are definately the same injectors but who is reselling them with those numbers im yet to find out...
Bottom row
EDIT...actually i think mine did have the same 87091 number as yours...either way they are not nismos..google an image you will see the differnces in shape..
Edited by Arthur T3
I beleive they will work just as welll as the nismos but nismos are a direct fit.
these will drop in but you need spacers around the top...you can buy these..
http://www.nengun.com/sard/injector-collar
maybe cheaper somewhere else, these just the first ones i found.
You also need to put an extra o-ring around the top, i used the old ones off the stock injectors..
they are direct fit for a supra JZ if thats gunna help ya selling them...
yeah and soarer, i actually thought they were stock jzz30 for a minute until i saw the part number on the box.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
