Hey guys,
I just put in my amp and sub and it sounds pretty awsome. Jus how i wanted it, punchy bass without the whole car shaking. I guess the secret was using a decent sub and amp (i got a top of the range alpine head unit, Alpine splits and rears and now sub and amp) and the wiring i used was top quality as well (went a fusion wiring kit as the alpine kit was hard to find and also way 2 over priced) I set it up so i can easily take the sub out if i needed to use the boot. The amp was mounted on thin MDf bored with some checkerd paper on it. I used the original plastic nut holes, using metal nut and bolts to hold it all together. this way i can easily take it out if i needed to. My biggest problem was what sort of sub enclosure i should use. I ended up using a fully sealed box which i picked up from gary's car audio for 50 bucks. Big thank you to everyone who replied to my thread on what sort of sub enclosure i should use and also to NS2500 for his thread on how to take the headunit out. Saved a lot of time. Pics up Now.
https://www.sau.com.au/forums/topic/34157-just-put-in-my-amp-and-sub/
Hey guys, thanks for all your replies. i finally put it in. I went with a fully enclosed box in the end. It sounds pretty awsome. just how i wanted it to. thanks for all your advice again. If you wanna see pics, go here.
http://www.skylinesaustralia.com/forums/sh...4948#post685073
Edge:
Well its sealed fairly flush, I wouldnt say its air sealed. But as good as the factory one (which was pretty much a weird sort of plastic that was carpeted) my partial shelf is exactly the same, just used mdf so it could hold the weight of the Amp.
95GTST
Im pretty sure i just bought a single sheet of 9mm thick MDF from bunnings for like 10 bucks.
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
