Hi guys, thought I would join this forum (I am from GTROC in the UK) & work for Newera Japan.
I have owned several GTRs, with my last R34 GT-R going to its new owner last week.
It's new replacement however is now on its way from Chiba from a friend of mine (Gio) who created this amazing BNR34 from scratch with the help of Top Secret. Newera filmed this car in Japan & took it for a 320kph + run on the wangan back in 2006 when it was in its previous lesser state of tune…(video is on youtube)
Some of you may have seen its now updated look & spec it on a friend of mine (DCD) blog on speedhunters.
CAR FEATURE>> TOP SECRET COMPETIZIONE R - THE REBIRTH - Speedhunters
mmmm snug interior....Robson goodness....
nice welding...(drool)
Recent dyno
Brief Spec
Engine:
- Top Secret prepped block (oil/water galley etc.)
- HKS Step III 2.8 L kit (87 mm x 77.7 mm)
- Nismo N1 bearings and seals
- HKS IN/EX metal gaskets
- Trust extended oil pan and pick up
- Trust oil pan baffle plating
- HKS Metal Flow air filters (x2) & polished speed density conversion
- HKS GT-2835R A/R 0.73 turbine kit (x2)
- ARC Pro Class twin entry intercooler
- Nismo GT surge tank
- Top Secret/NAPREC custom port matched
- Custom NAPREC ø49 mm oversized throttles
- HKS exhaust manifolds
- HKS GT wastegate (x2)
- Top Secret Drag front pipes ø 80 mm
- HKS Metal Sports ø 75 mm sports catalyser
- Trust Ti-R titanium exhaust system 90 mm
- Bosh Motorsport 550 fuel pumps (x2) & Nismo in-tank fuel pump
- Top Secret fuel collector
- Earls custom braided fuel lines & fittings
- Sard fuel pressure regulator
- Trust Grex fuel rail
- Top Secret/Sard 1000 cc/min injectors
- Top Secret SPL ported & polished head
- HKS 1.2 mm metal head gasket
- Tomei head bolts
- HKS 272º & 10.5 mm lift (IN/EX)
- HKS Limited Edition Valcon V-Cam Pro 16/30
- Tomei valve springs (double)
- Tomei titanium valve retainers
- Tomei valve seats
- Top Secret slide cam pulleys
- Top Secret Super timing belt
- Blitz Racing 8 spark plugs
- Nismo N1 engine mounts
- Trust oil pump
- Nismo N1 water pump
- Yashio Super Race radiator
- Sard Type-D thermo
- Sard water filler cap
- Billion polished power steering fluid tank
- Top Secret oil catch tank custom rerouted into intake
- HRD 130A High Power alternator
- M-spec Nur high power battery and upgraded lines
- HKS 15-row oil cooler
- Trust oil filter relocation & HKS billet filler cap
- Top Secret oil bypass collector tank & Earls lines
- Tabata RR Race radiator & HKS cap
- Garage Defend carbon radiator shroud
- Samco silicone radiator hoses
- Robson carbon fan shroud
- Robson carbon fuse box cover
- Robson carbon spark cover
- Top Secret chromed engine covers
- HKS F-Con V Pro fueling computer
Transmission:
- ATS twin plate carbon clutch with 1350 kg pressure plate
- ATS lightened & balanced flywheel
- Nismo Spec III racing clutch operating cylinder
- Top Secret Super Release shift fork
- Nismo large diameter input shaft
- Cusco Type RS rear LSD
Suspension & Brakes:
- Seam welded chassis by Top Secret
- Nitron Pro NTCNIO12R 3-way adjustable racing suspension kit
- Cusco adjustable rear upper arms
- Top Secret HICAS remover kit
- Ikeya Formula front pillow adjuster links
- Ikeya Formula front upper links
- Ikeya Formula roll center adjuster lower arms kit
- Ikeya Formula tie rod ends
- Ikeya Formula multi-link spacers
- Ikeya Formula adjuster rear lower arms
- Ikeya Formula rear camber adjuster bar arms
- Ikeya Formula traction adjuster rods
- Ikeya Formula rear knuckle pillow bushes
- Cusco carbon Pro front strut bar
- Brembo 8-pot calipers with 380 mm 2-piee slotted rotors (front)
- Brembo 4-pot calipers with 355 mm 2-piece slotted rotors (rear)
- Endless CC-R brake pads
- Top Secret braided brake lines
Wheels & Tires:
- Spark Silver Volk Racing TE37 19x9.5 +12 (front & rear)
- Bridgestone Potenza RE-11 275/30/19 (front & rear)
Exterior:
- Top Secret custom dark grey blue pearl paint with glass coating
- Nismo Z-tune front bumper
- Top Secret carbon front diffuser
- Nismo Z-tune front fenders
- Nismo R-tune carbon vented hood
- Top Secret carbon hood dampers
- Do-Luck side skirts
- Top Secret rear carbon diffuser
- Top Secret rear carbon vortex generators
- Ganador Super Mirror
- Nismo dry carbon rear wing blade
- Custom Top Secret carbon wing mounts
- Shaved 3rd brake light and lock from trunk lid
- Top Secret smoked LED fog lights/reverse lights
- Sunline Racing v2 LED lights with LED blinkers
- Nismo front & side smoked indicators
- Nismo carbon pillar garnish
- R35 GT-R front grille emblem
- PIAA carbon type wipers
Interior:
- Top Secret custom spot welded chassis
- Top Secret/Personal steering wheel with Robson Leather alcantara & blue stitching
- RBH boss
- Ronson Leather custom carbon/alcantara upholstering
- Robson Leather carbon center console & various inserts
- Robson Leather alcantara headliner
- Nismo Combination Meter
- XaNavi Birdview navigation system
- Blitz Type-R Dual SBC
- Nismo MFD Ver. 2
- HKS Type 1 turbo timer
- HKS Variable fan controller
- HKS V-Cam controller
- NEKO Corporation AF700 A/F meter
- Pioneer DEH P919 head unit
- Top Secret gear knob
- V-spec II pedal set
https://www.sau.com.au/forums/topic/341588-hi-everyone-nice-gt-r-pics-enclosed/
Impressed.
Start a thread in the project section for the black one and your ae86
Thanks i may do that, but tbh the car (again isnt black lol) but its one of the most complete GTRs built.
There isnt anything else that needs doing to it (or avaliable), you name it, its prob got it lol
ive put a few pics of japanese GT-R meets here:
http://www.skylinesaustralia.com/forums/Ja...iaries-f64.html
see its not black (pics from DPA gtr meet)
Edited by mattyneweraimports
^^ :worship:
You obtained a Top Secret built R34 GTR, which is wicked!
How are the twin high mounts?
Is there lag in them like a single high mount or are they quite responsive?
extremely responsive, check the dyno. Its a HKS Step 3, 2.8.
The v cam helps the response as well
this is one of Nagatas favourite R34s.
Its been re built twice by them, the final incarnation is what you see above.
All genuine parts have been used, such as the Nismo full body kit, etc
There is alot of work which the photos do not display, attention to detail, such as the Robson leather interior or all the suspension work underneath including the seam welding
  1. Surely this surpasses the $250,000 sale of a Z-Tune (or maybe at least in build cost)
  2. IMHO this pretty much sh!ts on a Z-Tune not only in terms of performance, but visually
  3. This is pure car p0rn, please dont change the way it looks
  4. What they've done here isnt fair to everyone else, all other GTR's now seem inadequate... similar to that of a man with a small ____
  5. Top Secret and Mr. Nagata have outdone themselves yet again
  6. What on earth was your friend thinking when he sold this? This car would complete a man's life
hi yes the build cost is throu the roof, however what you have is one of the (IMO) best GT-Rs ever created
Things like the bonnet is £4,000 GBP, the v cam system is a limited run (That only the tuners have) not the mass market v cam, your price above would just about cover the engine build and the aero i would think
my friend was very good to sell it to me, his owned the car for many years in various states of tune thro top secret
(i think his nuts too but hey ho lol)
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
