we go every year, and its always good fun
Newera are given press passes , which allow you into the hall before the masses
allows you to go talk to the exhibitors and to look up close at the cars, before everyone else does.
Moving through the hall, there were move delights on show, including the cars ;-)
This was my favourite stand ….the guys at hks kansai are great
They are even doing some custom work for my r34 which is on their demo car…but because we asked nicely they are going to produce it for me …wahoo!
r34 features the nismo z tune front and rear arch trims
Under bonnet
R35 demo car – expect to see group guys on these shortly
New r35 water cooler
New r35 lsd in development
New tomei rb28 set up
New turbo set up for r32-34 gtr – 300bhp output each
Gtr muffler will follow in same style , r35 one being developed in conjunction with new era japan and tomei
New wheels from bbs
Hasemi grtr demo cars
Coolest stagea ever….
Runs an rb26 d jetro
Wicked ae86
https://www.sau.com.au/forums/topic/341598-tokyo-as-2010/
  • 2 months later...
aawesome!
+ 11 ty.
this thred delivers, passed by a few times but i thought id comment. hakosuka stagea makes me spew in my mouth but i luv the nismo xanavi super gt car. hoping to get back to sepang circuit or even fuji in a few years. great range of cars and parts. more pls. btw i heard about the nur RB28 v-cam top secret R34 GTR. nice one, i remember the 1003hp R33 in Maxx Power magazine from the UK. i like rare expensive stuff.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/341598-tokyo-as-2010/#findComment-5610819
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
