Hi Tridentt
He has FMIC, ECU, injectors, fuel pump.
He needs turbo, spacer, oil & water lines, dump pipe/exhaust mods(assuming he doesn't shoehorn it into a nissan turbine housing), tune and labour. It should be less than $5k from here on stock bottom end.
  • Replies 44
Posted Images
Depends what turbo he opts for, a HKS 2835 or 3037 will nearly set him back that on its own. A 3076 is around the $2K mark then dump etc plus tune............I'll stick to my $5K, though he might get change for a meal at Macca's :)
And I did say depending on his final preference btw [my out for overquoting :)]
3076r turbos r around $1600 delivered mark and any mechanic tuner could fit one for around $500 mark... f**k me u guys must get completey ass raped with pricing and labour lol feel sorry 4 ppl paying 4 the NAME. haha
I say we go to Quay or somewhere poncey with the change. :)
Plus a dump pipe say $300, dyno tune $500-800, air intake pipes $300, oil/water lines $250, heat shield $100 = $3700 and I probably haven't thought of everything?
You can't do it for peanuts, plus I know I purchased my 3076 for $1600 but that was 2-3 years ago and if you go to GCG or someone its closer [last time I looked] to $2000. So if I use that then total is $4100.
And I bet he'll need a new mani gasket and studs, so add another $200 plus labour. And with that sort of turbo I'd have an oil catch can installed so add another $200.
Shit if he took some of the other prices being bandied about, he'd have a half built car and no $$$$ left to finish it.
Also, I just looked at the slide show, he needs to find out what turbo he has? I see that he has a HKS actuator, the bit of turbo I can see doesn't look like a HKS unit, but it's hard to tell what it is.
mate ive been there and done this turbo so im going off experience :)
u can sit there and name prices all day long. and if u spent $4100 roughly then your a sucker.
So have I and if you can find parts cheaper then good for you, but every price I've listed is pretty much what the market rate is, if you can build one for less then you must have got a heap of free bits?
air intake pipe $300?
4" 90 degree stainless bend $40 ( from stainless shop )
4" k&n filter $80
4" silicon hose $22 (ebay thru proboost)
clamps $10
$152 total
but feel free to spend $300 on a intake pipe?
want me 2 keep going
custom oil feed line $100
drain bolts up perfect
can modify the ends of factory water lines to suit the gt30 housing think i paid $65 thru enzed with new ends
so $165 for water/oil line setup.
Im sure he already has a 3" dump of some sort
so any NORMAL person would modify the existing dump to suit the new turbo which would be 2 parts of f**k all maybe $100 if your lucky.
him replacing his manifold gasket and studs is completey up 2 him, manifold doesnt really need 2 come off unless he wants 2 go external gate setup and run it from the manifold, i had 4 studs missing for 3yrs and never leaked.
tune would only need a touch up not a complete retune so around $200-300 ( like i said alot of guys pay 4 the BIG fancy workshop name 2 tune it and get shafted )
Remember that is an externally gated turbo, internally gated turbos are more expensive
he could also run the external gate setup from his exhaust housing, which i done for 2yrs and is prob the best setup ive ever had, my tuner done that for $200..
It's an on the spot $800 fine in vic, Tao from hypergear got done with this.
wouldnt the fine be the same no matter what as you aren't running a stock turbo, external internal or external via the housing doesn't matter?
yes i know this
only a few hundred $ between them though.
well if u live in vic ur f*ked then, move state and mod ur car.
I was fined for a high mount turbo setup, POD, and BOV, I had internal gate. $760 fine for the EPA. Thats the worst fin I've ever cooped.
I was pulled numerous many times since. How ever the internally gated turbo with stock manifold wasn't some thing on the defect list.
The current fine for ext gate or de-cat is $4600. You can pass it onto the person who've done it for you if its not your self. I had a customer cooped that, dragged it on and ended up with $5200 fine. He had to strip and sell his joy to pay it off.
The EPA in Vic is BS. They need to re-think they fine structure based on people's income.
dont think i need a thicker head gasket till i break 500hp i heard the stock internals can handle over 550 .. but considering the Gt3076 i rang up the turbo tuner today and he was sort of talking about a Gt28 Hybrid where they take my old turbo out and machine out the compressor housing or someshit.. and it produces way more torque + hp n u can notice the difference and its much better for street racing apparently he reckons. so ima get my car run over the dyno next friday because he wants to know the power run results.etc etc.. also i dno if a GT3076 would fit because my turbo is low mounted theres not much room if u look at the pictures where the PODs poppin out..But i guess its his job to make it fit right? gotta run new oil + water lines to it aswell.. probly only looking to spend about $3000 at the most anyway.. its $1290 for the turbo itself ..so yehh ill keep u's updated .. Still not sure what the hell my turbo is xD cant get in there close enough to have a look.:down:
lol @ your turner and his recommendations
gt3076r fits fine down low.
im running gt3582r atm but have had the 3076r down low aswell on same setup
Edited by l0WRB
the turbo he is talking about is your run of the mill highflow, check out the dyno sheets from hypergear and gcg for some similar results.
stock internals will not last making 500hp either, 400hp at the wheels would be the absolute max I would run through a standard motor, even then it wont last forever.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
