Got a r32 gtst that has been in storage for the last 3 years after a minor front end collision (only very front stuff like intercooler, radiator etc damaged).
It still has half a tank of fuel in it but of course this is now 3 years old. What happens to the fuel after this time? What would be the damage in keeping it in their to try and kick the car over?
I've got all the parts on it now I need to get it started (it had most of the engine goodies stolen).
Should I try and kick it over as is or is there stuff I should do/check first after an engine has sat for so long? Do they seize?
Any help much appreciated thanks!
should be fine. just check the oil. probly wouldnt hurt to take the rocker cover off and pour a little bit of oil over the cams.
Before you start the engine, remove the spark plugs, then turn the engine on the starter motor and make sure you get oil pressure. Once you have oil pressure, it is safe to actually start the engine.
The fuel will be fine for running the engine on low load, ie basically idle and low revs.
just started my r33 after 5 years without starting. fuel goes off best bet to drain or change fuel filters a few times. the other big one is oil gets very sludge in engine oil. recommend new oil and filter before starting and definatley crank untill oil pressure present. recomend using a deisel enmgine oil 15w40 as it has a really good deterigent in it to help clean out the engine. drop it a few times after starting to make sure all the crap is out of it.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
