im after a genuine R32 GTR nismo speedo as mine was swapped over for one with less klms when it was imported.
preferably with around 68,000klms as mine was complied a few months ago with 67,000.
https://www.sau.com.au/forums/topic/341659-r32-gtr-nismo-speedo/
