AS FEATURED IN ZOOM MAGAZINE ISSUE#75 Came out on Friday the 20th Feb
Fully built & tuned by MIDORI, i have all receipts and documentation for over
4,100,000 JPY in parts and labour.
$38,000 Firm
Car
BNR32 GTR
White 1994 Model
Genuine 60,000 Kms
Fully Complied just before May 7 cut-off (Mack @ Complete Compliance)
Rego Till June
60% Tyres 245/45/17
Handling/Aero
Midori Carbon Fibre Front Lower Lip
NISMO N1 Front Bonnet Lip
NISMO Rear Boot lip Spoiler (main spoiler removed)
17" N1 Rims (White)
Midori Aragosta Fully Adjustable Suspension
Midori Adjustable Castor Rods
Midori Adjustable Negative Upper Links
Midori ALCON 355mm Aluminium Hat 4 pot Brakes with Pagid Endurance 450 Pads
CUSCO Strut braces front & rear
CUSCO Rear Diff
Interior/Electronics
Stadard Trim
Nismo Racing Pads (on door and console, stop you moving around in seat)
Greddy A-Pillar pod with twin greddy temp gauges (oil & water temp)
HKS 80mm Boost guage
HKS EVC Pro Boost controller
NISMO White face Gauges
NISMO White face centre gauges
Engine
BNR34 Head
BNR34 N1 Turbos
Prepared BNR32 Block
BNR34 N1 Floating assembly
HKS 264 cams
Tomei Adjustable cam wheels
HKS 660 cc Injectors
Bosch in tank pump
Grex Oil filter relocation kit
NISMO GMAX II Clutch (receipts for new plates brought in from japan)
HKS Twin Power Ignition Type DLI
MIDORI Modified ECU
MINES Air Flow Meters
Cooling
BLITZ Oil cooler with earls lines & fittings
TRUST Drag intercooler 600x350x130mm
MIDORI aluminium radiator kit
Exhaust
HKS stainless dump pipes
HKS Mild steel front pipe
HKS Mild steel 100mm system
HKS Stainless rear muffler
I have not put the car on a dyno, however, i assume after looking at other similar setups that the car should reasonably make 420-450 RWHP...Definitely feels like it!
I would estimate low 11sec performance, but i have not run the car on a strip and this is only an ESTIMATE. The car is specifically setup for street/track duties.
Bought the car almost 12 months ago. Car was fully imported in my name and by myself. I have all documentation and papers to show for this, including my import approval and 0-4-5 cert. which i need to supply to the new owner under new govt. regs.
Asking price is $38,000
Digi picture can be sent via email, pictures will be in the mag and you can arrange an inspection by emailing: [email protected].
I can supply extra photos of specific parts if needed...
T.G.
https://www.sau.com.au/forums/topic/34171-midori-bnr32-gtr-for-sale/
  • Replies 49
PH1: Goto www.midoriseibi.co.jp and look at their brake kit section. My brakes should be in there. Perhaps they are 350mm, regardless, they are worth about $12,500 are cool, big and stop really well. I hope your question has been answered!
Rusty666: I didnt do the mods, as stated in the first message, the car was FULLY BUILT by MIDORI in Japan. I picked the car up during an auction.
As much as i am sure you are interested, i have yet to see a 16 year old with 45k to spend. If you are interested then i will email pictures, if not then please dont waste my time.
T.G.
Yeah the webpage says 355m, I'm just curious how they fit tho, they must be pretty tight. I also have 355mm rotors on my 33 and theres no chance of getting the std 17" rims over them. The webpage also says 395,000yen, which is a lot closer to $5000 than $12,500.
Anyway, can you please email the pics as I am still interested.
PH1:
Pics emailed.....
Yes they are 350 000 JPY but that is not the kit price (even though it looks like it). That is the price for the Rotors with calipers. Im not exactly sure what the brakes are worth now but add ateast another few grand for braided lines, pads, brackets etc.
The point is that i have receipts for 950 000 JPY which equates to around 12,500 AUD.
bnr32 is right.. when i went to buy brakes over in japan, the brochure price only ever included the calipers and discs, no matter what car the brochure said it was suited for.. $7500 for pads, and a couple of brackets is pretty steep thou. interested in the car myself, but its a little more than i want to spend, any more pics of the whole car ? where are you located? how many k's
sic200,
I have still go the car for sale. Featured in tradingpost last week and is still in there for another 2 weeks. Check in there and also check issue 47 of zoom page number 64...
If you are interested then call me, number is in the advert in statewide tradingpost.
TG
V8 Supercars run nice low profile calipers (like the CP4370) which let you run 375mm discs in a 17" wheel!!!! Noice!
Havent checked back here for a while....
Still selling car, i would like to say to the two WANKERS that rang after seeing this post, thanks a milion for making me wait around all Sunday and not showing up!!
CAR STILL FOR SALE, 45K NEGOTIABLE....
TG
Gojira: No the car is not running standard internals..... running BNR34 N1 rotating engine assembly (cranks, rods, pistons, rings etc)....
Midori supply these rotating assemblies as a kit or installed, i guess tehy purchase the N1 spec parts from Nissan/Nismo and assemble in customers car..
TG
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
