Hicas - Im Very New To This Car And Would Love Some Input
Hi again, i know this topic has been covered abit in the past and ive been doing my best reading through old posts hoping to find my answer but had know luck yet so i figured i might aswell just straight out ask, i bought my R34 gtt about 2 months ago, when i was testdriving it i even asked the salesman why the HICAS light on the dash was lit up and what it was for, and he just said its to tell you its working properly and then changed the subject, now all my life ive wanted a nice skyline but that doesnt mean i know a thing about them, i know this is gana sound silly but yeah i dont really even know what the HICAS does properly. I soon figured the light must be on for a reason other then what the lier salesman said but there doesnt seem to be anything wrong with the car, i dont know what i should be thinking may be wrong either, could i be causing my car damage driving it with this light on ?? I would love all the help and ideas i could possibly get on this topic, it would be greatly appreciated... Thankyou so much for taking the time to read this...... Cheers
Elle.. :-)
i assume you know hicas is the 4wheels steering in skylines. if the light is on, the car may have had hicas removed or the hicas may have a fault. post a pic of the underside of your car looking at the diff from the rear. that will show if your car has had hicas removed
most people remove the hicas because it has a mind of its own and sometimes tries to do things you aren't expecting. makes driving your car hard a little dicey when you are having to correct for what the computer is doing and it tries to correct for what you are doing at the same time. removing it also saves a bit a of weight.
unless you go with a tomei hicas removal kit or similar, which fool the hicas ecu, you'll have the light pop up. these kits are exxy though and people generally just remove the bulb from the dash. free and easy.
however, do get it checked because the light may also come on for a fault with the system or orther related stuff. i have no knowledge of this aspect so better wait for other replies here or take it to a mechanic to get it checked out.
meantime, look through these two threads. the info you need is likely to be in there. btw, i got these two simply by searching. try that next time. might save you a bit of time:
Hicas removal on a r33
Hicas diagnostic
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
