Golgo fails EPA noise test with flying colours!
OK - so if I had read 91dB, I would have been cross, so to prepare, I fitted a CAT (thanks Gerald) and prayed to JASMA hoping for a legal pass...
97.8dB @ 5400 rpm!
Worth doing, worth doing properly :)
I think that's something like 6x louder than it should be?
The tester liked my titanium system, didn't charge me for the test - and said come back with a stock system for a big tick.
So... does a GTST stock system fit on an R?
Anyone got a stock R system lying around?
BTW: Sounds sucky with a cat. I know what will be going back on when the test is passed. Can't take away Godzilla's fire breathing ability :(
Don't think I just smart ass, but wouldn't it be better sense to make your own and keep it. If you have been pinged for noise once and you plan on going back to original after testing, surely you can see the possibility of getting done again. So! it would make sense to have your own spare stock system hanging around.
My system finished will be 3.5 inch from wategate entry back. 3 inch dump, 1.75 from ext wastegate, then 3.5 all the way including the cat. I'm sure I won't pass noise levels with this, so I will have a 2.75 press bent system on hand for just these occassions.
Guest RedLineGTR
Yah thats cool i know what you mean but honestly 90% of the GTRs i have seen in vic have come of the boat with a aftermarket exhuast...and most people keep it on as long as they can if they get EPA'd then they will look for a stock one. OH well i'm sure it will get sorted out soon.
Also just wondering why would a importer import a container or stock exhaust they make the money with aftermarket parts thats why its sometimes hard to track them down..and with the new importing scheme less stock parts are avaliable. My 2 Cents :)
On the strength of the imports having a/mkt systems, maybe the go would be to strangle the sh1t out of the system at the end.
make up a bolt on for the rear muffler.
Drop the big 4/5 inch canon and put on a restrictive stock muffler, just for testing.
Let's be honwst, for testing nobody care about performance, just limit the noise.
Would be a lot easier than changing the whole system.
James, I understand you have a cat replacement pipe. Why not get another made with some mesh welded in and put steel wool in front of it. Will strangle hell out of it and make it quiet as hell but will be no fun to drive.
Do the testers check the system for cat etc?
Would even a basic restrictor such as this work? even out of just sheet metal.
| o |
You could just bolt in behind the cat, if it wasn't visible doubt they could tell, and it *should* quieten down the noise. Most silencers I have seen are little different that just reducing the diameter of the pipe.
Jamez..
i have the stock GTS-T system for rainy days :P and what i suggest is that you take your rear muffler out and have a pipe made up to fit the stock muffler to your existing system....
i kept my 3 1/2 inch system, simply took off the rear muffler, had an 'S' pipe made to fit the stock muffler to the 3 1/2 inch sytem, 100+ db reduced to 83db... :mad:
it takes two bolts to undo to replace the beast muffler back on...:(
and you are welcome to borrow my stock exhaust/muffler...
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
