hi,
does anyone know where it's situated on the RB20DET block. reading threads on site, its mentioned for the rb25 and rb26, but couldnt find anything on the rb20.
is it this by any chance? located beneath the exhaust manifold, and beneath anoher line which leads to the turbo?:
thank heaps
Edited by rayj
hi,
thank heaps
That's what I would refer to as the coolant drain
it's one of the coolant lines for the turbo
probably the lowest point
apart from the bottom of the radiator, if you want to flush it all out open the plug at the bottom of the radiator and start the engine and make sure the heater is on full ball. when coolant stops coming out it means there is nothing left in the system
whats the bolt for at the bottom of that line? the top is the into the turbo, then there is a 14 bolt under it, is that the coolant drain?
hi,
thank heaps
just in case somebody comes across this thread oneday, that bolt in the pic is indeed the coolant drain on the rb20det
i personally wouldn't go undoing it everytime you want to drain out the coolant in your engine as it is a banjo bolt so it has copper washers that *going by the book* shouldn't be used again once you take them off
also it's a hardline so once you take it off it will no doubt move a bit and then be a total cunt to get back on
Edited by mystery_kid
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
