Im with tru as well... and I dont know if you guys get it, but once every 2 weeks or so i will get some d*ck knocking at the door at about 6pm saying im from so and so company and ive been sent here because the standard elec/gas provider in the area is charging too much and we dont want to sign you up we just want to save you money, here are all our bs facts and as you can see we will save you money...
.. if:you:sign:up:for:20:years:straight:and:if:you:leave:early:we:will:take:your:le
g...Sign here!
try these:
http://www.switchwise.com.au/
http://www.goswitch.com.au/
I once used one of these to compare my current plan to others... it was maybe $30 less for the year on someone else plan but had to be locked in and change everything around... f that... i rekon if its less then $100 you save for changing over its not worth it.
gl with it
One other thing to note is who owns the company you go with.
There are a few with a large percentage owned overseas. Victoria electricity is about half owned by an NZ company, not sure about others - so your money leaves oz for the sake of a few bucks.
Im with Vic Elec - although they merged into a larger company or something.
10% discount for early bill payment too ontop of good rates
Saves me a good $100-$150 over a year, if not more. Not quite a "few bucks" - could be as much as $200-$250 over a year with reduced rate also
Competition = win.
Yes must agree there are some good deals to be had - I was on Vic Elec for a while was getting 7% or something for on time.
I have been on the 100% green for a little while now but you don't get any of the good offers on it - they all seem pretty close price wise. Gotta help offset my fossil fuel burning habits somehow!
This bit on switchwise is good for getting a rundown of the companies and any overseas interests
http://www.switchwise.com.au/electricity/suppliers/
Vic Elec / Lumo is 100% NZ it seems
TruEnergy is owned by China Light and Power after a quick browse.
There isnt much diference when it is a straight swap offered by people on the phone of door to door knockers... unless u seek a proper deal, it is not worth it cos some of these people transfer you wrong from one company and you end up getting youre power disconnected in the process untill u ring them back and get someone to reconnect it for u which can take up to 4 hours... how do i know? i work for the transmission and east distribution asset owners, part of my training was taking EMERGENCY FAULT calls and there are 12589712409 people asking about billing, reconnections and etc... we arnt retailers but most dont know the difference and call us anyways. That y i say, if they come to you, forget it cos they just want commission and slap you with there plan... But if you go to them you might win...
im with AGL and they are hopeless, billing is horrible
you might be in contract with origin, if you arent then all is good
Well luckily i am not locked into a contract with Origin. Apparently, from what i heard, origin is the most expensive out of all but provides the best service. I live in an apartment, so i doubt i will need any service from them.
Competition = win.
I was looking through Vic Elec as well. Do you get the $100-$150 savings every month or at the end of the year only? I want to look at the charges per kWh. Some companies have Peak and Off Peak charges some don't.
Origin charges me by the first 1020kWh at 17.7cents then subsequent kWh at 18.99cents before GST. A bit steep i reckon. Service charges is fixed at $57 per quarter. I live in a 2 bedroom apartment in the city and i recently just paid $418 from june to sept. :D
Anyone care to share their charges? :P
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
