  • Replies 226
They would probably have a big enough customer base for RE55's just here on sau Lol.
Absolutely. I reckon I could put together 5 sets with the people I know who want them pretty easily.
How about it Tirerack? RE55s? (or D03g Dunlop, or Yoko 050)
Edited by R32 TT
Tire Rack was very helpfull with my quote and then my requote when I wanted the sizes changed a bit, and when I transfered the funds the tyres were on their way the next day, TIRE RACK you rock.
My tyres have been released by customs and are about 30 Klm away, LOL, its taken 4 days to travel 15,000 Klm, how long will the 30 Klm take ?
Im guessing another 4, lol....
  • 4 weeks later...
Slightly more road noise than I would have thought for a hi po road tyre, but grip in wet and dry so far is excellent, well worth the slight raise in road noise, lucky the 044 no rear seat and induction noise drowns it out.
Will be getting some 265/40 17 for my track day rims for sure, I just need the car working properly so my old Dunlop DO1Js finally wear out.
Thinking about some 19" Conti's myself, which did you go? Have they arrived yet & if so any feedback on them?
cheers, Tim
Conti's are on their way :thumbsup:
19" tyres - $270 Econ shipping. Got no idea why so cheap!
Loving the Tire Rack Experience so far.
cheers, Tim
Arrived - about 6 days I think. 225/40 19 Extreme Contact DW. $205 US each when bought. Have only driven them for one day so far, but impressions so far are good. Don't know why they are cheaper than sportcontact range, they are a German made tyre. Great overall grip, more compliant in the ride than I expected, which is nice. Feel a little dead just off centre, but the overall grip is great. They have the one of the best reviews on the site I could find.
Tirerack experience was great.
good stuff. you will love them. :) they're my favourite budget/midrange street/track tyre.
I have a set of those on my car now. Does anybody know what I should start them on, cold pressures, hot pressures. Doing a trackday soon.
personally (and this was on my evo 6 RS) I found they liked higher pressures than the track tyres I normally use (semi-slicks like A048/A050, RE55 etc).
what track is it?
given you have a R33 GTR I would start with around 32-33psi cold. they seemed to work well for me around 36psi hot, they might like even a touch more on a heavier car, maybe even try 34psi cold, do 3 laps or so to see how they feel, come in and check the pressures and adjust as needed from there. you should have it pretty sorted after 2 or 3 quick checks.
  • 3 months later...
Did all of you guys have to pay using wire transfer?
They stated at the bottom that they accept credit card and paypal but when I emailed them, they only do cc and paypal for US customers, Aus is only wire transfer...
Yeah wire transfer, 5 minutes in the bank, easy as.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
