Got a few intercoolers as well taking up heaps of space
front mount for an R31 $50
CA18 ARC intercooler kit $350
you can make this fit the R31 pretty easy
Stock R32 Gtr intercooler $250
paint removed for hecticity
Trust Gtr drag intercooler $350
modified for an r31... this is a big f**ker 120mm- came of a zed with 500rwkw
some bent fins and minor dents but would clean up easy enough
Generic China IC $70
I had this on Memphis good core (if a bit heavy)
Last one is off a Gtr $400 or $800 with piping kit
big core 130mm
supposedly a Trust drag core
has a 3 inch inlet and 4 inch outlet
polished to within an inch of its life
I have big hands (for scale)
Located in Blue Mountains Sydney
Pete
0448468884
https://www.sau.com.au/forums/topic/341820-skyline-intercoolers/
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
