I have been reading up on some of the regulations and items included as factory options can be run on the car provided they are included in the homologation documents that were submitted for the car or are included in factory option brouchers.
I have recently obtained a factory options broucher that covers R33 GTS25T Series II and GTR's.
The obvious items on your car are the side skirts and the front Nismo lip that were factory options. The GTR adjustable rear wing was also a factory option that may provide some improved aero over a stardard Series II wing at speed.
If you are interested I can scan the broucher and email it to you if you have any difficulties with CAMS or other officials.
I weighed petes car a couple of weeks back. I ran out of weights trying to substitute him.......
It wasn't overly heavy for a GTR.
I rekon neil's will come in around the 1300kg mark.
I think mine came it at around 1370 kg full of fuel at EC's weigh bridge, don't know how accurate they are though.
Thanks Charles that would be very cool,,,even just for the look see. Sorry mate I have no side skirts and my lip is M spec not Nismo.
I'm a firm beleiver that if a part is listed for fitment as an accessory or option by the manufacturer or it's race arm then it should be allowed to be used. Unfortunately I think CAMS see it differently.
Brad,,,I weigh 72 kilo's so please no setting up for Larger Gents and Cheryl has had no real weight reduction yet,,,she still has her intrusion bars.
Cheers
Neil.
She comes in at 1295kg with the screens fitted.
Same condition as when you dropped it off Neil.
It has a 50.52% (drivers side front biased) diagonal split with a 70kg driver ballast.
59.6% front heavy which is typical. Front being 769kg's
I've got center of gravity heights and roll couple heights for you as well.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
