flashy brakes bro
Yep they do look flashy,,,but you know me by now,,,they have to fit perfectly. Remember I'm anal so the caliper has to sit perfectly in the middle of the disc. I machined up some spacers tonight but I don't think I got them right. Someone has built the dog-bones beautifully so it's just a matter of me making the whole package work to my liking,,,I don't want un-even pad wear or pad knock off big fella. Time and work will tell if I actually use them.
Cheers
Neil.
I've been stuffing around with my cold air box and thought what the hell am i going to do with this hole which used to be a factory intercooler inlet,,,
So after a bit of thinking and a little trip to Bunning I thought why not buy these bits, They cost all of about $15 bucks.
Bit of a mock up fitting and another easy pessy air intake,
It's far from finished,,,as I think I should put some mesh over it,,,just to stop the gerbils from getting in but this took stuff all time,,,not like trying to re-fit my R33 GTR snorkel to the top of the box,,,that's still a work in progress.
I finally finished my cold air box,,,it all went great until trying to make my R33 gtr snorkel fit properly,,,lots of heating and bending took place and it's still not a 100% but I can live with it for the moment. The reason I made my own and didn't buy one is they are all made for street cars that still use the carbon canister which has a big cutaway at the front. Mines made of 3mm fibreglass sheet and covered in stinger roadkill sound and heat deadening insulation. The deadening was supplied by my good friends at Metrosound in Artarmon http://www.metrosound.com.au/ and I recommend them for anybody looking at stereo upgrades. If you look closely you will notice all the allen bolts are blue anondised aluminum and as usual my fetish for carbonfibre has extended to making washers as well. No sense waisting off-cuts. My next box will be made totally from carbonfibre but the funds are not going there at the moment. I really need bigger injectors and a turbo upgrade. Anyway here's some pics of my latest creation:-
Cheers
Neil.
Neil
Forgot to ask the other day
What pads are you running in the front?
I'm using Hawk DTC-60 HB178G.564's tiger,,, great pads and good pricing from Mathew at
http://www.racebrakessydney.com.au/
tell him I sent you.
I also use DBA discs exclusively,,,not that RDA rubbish.
Cheers
Neil.
Thanks mate.
also want videos of the hill climb this weekend.
Wander on over to youtube you lazy bum and search radicalracer41,,,oh here I'll make it easy for ya
https://www.youtube.com/results?search_query=radicalracer41
Cheers
Neil.
I used the DC60's from Matt at RBS great stuff BTW.
I used RDA and never had a drama, no cracking or warping very happy with them
Okay my bad,,,I should have clarified my dis-like for RDA. I actually don't like the way they run their business and until it changes I will never buy their product.
Love
Neil.
So now that I have my flashy 244 killowasps,,,this has bought me a new set of issues,,,
1/ My standard injectors are at a 100% so I need an upgrade,,,so I bought these 2nd hand ones off another SAU guy
555 Nismo's and tomorrow they are off to Unigroup for testing.
Issue 2 is my turbo,,,now I'm not going to move away from my high-flowed one but it's not right as boost is coming on at 6000 rpm and obviously that is not right. I and now Duncan have been driving around it but I now have the shits with it and it's time for fixing,,,again Unigroup will have the job of fixing it.
I'm not really after anymore power,,,just better drive-ability,,,but 300 will be on the cards for sure.
Cheers
Neil.
  • Like 1
yeah mate I reckon she'll be even more fun with that huge hole fixed in the power band.....it comes on boost like a 400kw car :(
and call on the injectors...I saw 100% on the PFC which is never good
love how it drives though, it is super predictable so you make the most of it.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
