Over the last 10 years I would have had 20 front strut braces on my R33's.
They have been from Jap and Aus aftermarket companies, fancy alloy ones to carbon fibre ones to steal ones plus a range of factory Nissan ones.
It all comes down to what are you trying to achieve:
  • if you want looks then go for the alloy or carbon fibre ones as they dress up the engine bay but offer questionable strength
  • If you want performance go for a R34 GTT for standard manifolds of a R33 or R34 GTR if you have a forward facing manifold - they may not look trick but they work and do not bend and flex
Charles I bought a R33 GTR brace off one of those idiots that think my strut towers are bent. It has a few scratches on it so it will get powdercoated as well.
After Bathurst it was time to fit my new door trims properly,,,so off came the left one and I thought why not get some weight out of the door 1st.
So after some very careful grinding with this excellent Medalist 1/4 inch die grinder I removed most of the intrusion bar. The pressed brackets are still mostly there but I'd had a few beers and called it quits before I f**kked the door skin.
Just as a side note,,,I was going to buy the disc arbor from bunnings but it was 20 bucks,,so with my little lathe I made my own,,left hand thread and all and it workes a treat.
After reading lots of bullshit on the interweb about how much a R33 intrusion bar actually weighs,,,heres the truth,,,no not 10 kilo's a side,,,I still have maybe 200grams left to cut out.
I was thinking about removing the central locking but the actuator and wiring weigh 100 grams,,,so I'll leave it.
I'd love to work out a way of converting the electric windows to manual,,, but so far no luck. I might have to buy a regulator and somehow weld a spline onto the reg for a handle. Thats a job for later though.
Cheers
Neil.
Can you fit a window strap like the old cars had, I think the MG or porka had some.
I think from memory the difference between electric and manual is minimal due to the extra weight of the winder mechanism, well that was the case for the Mazda anyway.
Rock and roll
Rock and roll
Hey Mark,,,great to see you still hanging around. I'm not understanding the "Can you fit a window strap like the old cars had, I think the MG or porka had some". I've been scratching my ancient old head and you have me stuffed.
I don't have a spare window motor to weigh but I did look at the specs of an older BMW today and they weigh 800 grams each,,,so with a lot of work I might lose about 1 to 1.4 kilo's all up.
Those door trims look a treat and are exactly what I'm after for my r33. How much were they?
I gotta tell you that I'm very very happy with them,,,for a race car they are perfect as they clear the roll cage intrusion bars beautifully. Michael did a great job. I attempted 3 times at making my own and I made crap. That all said they are not show car perfect but I never expected them to be. They cost me $430 excluding freight.
Cheers
Neil.
  • Like 1
GOOGLE " Project no-flight update ", its update 2007
It was a 65 Corvette
I believe others had them as standard, back when Jebus wore shorts, EDIT: Model T Ford did
So you pull the strap to get the window down and I presume you push it back up to close the window. How quaint. Nice idea mate but butt ugly.
Cheers anyway
Neil.
4th july you want come out and play
Thought I knew that date from somewhere,,,Thats Independence day for the Yanks!!!.
Whats on tiger,,,if it's just a track day then no as it's only 2 weeks before the Tamworth round which I should do well at.If it's one of those tarmac thingies you've been doing then yes I would risk the car (I have a navigator lined up). Ten rounds of the NSW hillclimb champs is a budget and time sucking series. Throw in the Aussie nats in WA and I'll be broke.
Cheers
Neil.
Awesome... Did you say you got hassled for no door trims at the track?
[/quote
The class I'm running in at state hillclimbs requires as much of the interior that is possible and door trims are possible. Besides it's a little dangerous not having anything.
Cheers
Neil
Cheers
Neil.
Not keen on replacing the glass with polycarbonate?
I've been considering it for my track car... I've bent up some molly rod, plan is to weld the rod to the door, hang tabs from the rod to secure the polycarbonate to with isolators. Install a pre-fabbed slide window.
Cheers
J.
most of the weight is in the window mech itself?
if you want to retain glass and you just want your windows either up or down (not at all) what about fabbing up a runner to hold bottom of the glass, brackets to hold runner attached to door via bolts - so if you want the window in and up its there if you want it out its 4 bolts undone and the whole window unit comes out ? but i spsoe if you go that far mose well go lexan
save about 5- 7 kg per door ? (my window mechs in r32 4 door weighed 5kg each)
my lexan window frames but are bolted in still not welded - so if necessary still easy enough to remove but strong enough to hold everything together
Edited by bcozican
I have told you over and over again big boy,,,keep an eye in your mirrors because I'm going to beat YOU.
Cheers
Neil
I love that front bar. Is it much lower than the stock one? Because I'm trying to get my track cars front lower so I can do a similar setup with a front splitter.
Okay I stuffed up,,,my door trims were $330.00 not $ 430.00,,,I must be getting old and losing my brains.
It took ages to remove the leftover rear section of the intrusion bar bracket and 200 grams it weighed,,,still have the front section to do,,,so that means total intrusion bar weight of 3 kilos' per side. Gotta do the drivers door next so 6 kilo's in total is a great weight saving.
I really really want to be able to wind the windows up and down so one way or another I'm going to stick with glass. Thanks for the ideas though boys,,,gotta love different peoples takes in getting the whole door situation lighter.
I have some doors coming so when I get some time I'll start playing with ways of flicking the motors.
Cheers
Neil.
To be honest Wilson I'm not really sure,,,I had the m-spec front bar and lower factory lip on the car originally but I smashed the shit out of it so I never got to compare the two. I think it is lower but not by much. This one is fibreglass which is much easier to repair slight damage so thats a bonus and is flat bottomed so fitting the splitter was a joy. Trouble is fibreglass doesn't bend so one liitle off and you will be repairing mounting holes of which I've had to do 3 times.
Cheers
Neil.
  • Like 1
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
