17 hours ago, Victory said:
It is great to hear from you Neil.
It sounds like country life agrees with you and to have a proper shed as well as a garage for your street cars is a dream that we all have.
Thanks Charles, we are very happy living up here. Hope all is well with you guys. Later on in the year Cheryl will get some much loving.
15 hours ago, Duncan said:
funny how you forgot to mention the rb30 swap!
And, if we aren't going to get any car pics, at least you should post up some shed pics :)
Kel mentioned Tamworth round is confirmed cancelled as well? Looks like I'll need to do club rounds at huntley or sdma
The rb30 swap was never ever going to happen. We have over the years enough wins and podiums to suit me fine. Cheryl will be used for club stuff and the odd Morgan Park sprints.
I know we all love big power numbers, but they don't translate to quick times, I have enough trouble with wheel spin as it is or was.
Car pics, bloody hell I rolled her out the other day for a wash (with tank water as we are on level 5 water restrictions) and that's all she's got since we moved up here.
Shed pics, really?, does anybody actually care how I design my shed.
Kel's right no Tamworth state round but they are talking about running a club round instead.
15 hours ago, fatz said:
I can also confirm Neil's joint is  good accommodation and storage for skylines when you crash them ( beer fridge always stocked like a good boozer)
I try my hardest buddy. Greta liked your car.
  • 2 months later...
  • 1 month later...
Popped down to Sydney on Saturday to pick up my 3 pallet loads of parts and my girls refurbished motor, Cheryl's engine is now home, thank god. I have to control myself as my plans at the moment do not include getting her in and running quickly, just nice to have her home.
  • Like 4
  • 5 months later...
  • 1 year later...
This is certainly no update, I get asked all the time for pics of her cage and the originals don't work anymore so I thought I would post some I took from today. Sorry she's a little dirty but it is what it is. If you need any more just ask and I'll post them.
  • Like 2
  • Thanks 1
I thought I would do a simple little job installing inner door grab handles.
Well bugger me the stupid owner hadn't lightened the drivers door, so out with the hydraulic punch set from Hare & Forbes CHP-60, 3 different size drills and much work. Two day's later and with some blood I ended up with this, why I think it's a good idea to try removing metal swarf with my fingers is total stupidity, but I got it done. 346 grams is no indication of the weight removed as that doesn't take into account all the drilling swarf also removed, more like 400-430 grams, so not far off 1/2 kilo.
So out with the door lock electric actuators which weight 130 grams each with the wiring will get a weight loss of about 700 grams. I'm a little annoyed, I really wanted to see a Kilo.
  • Like 2
On 17/07/2022 at 10:34 PM, MBS206 said:
Are you going back over those holes with a dimple die to make it stronger than it originally was?
The thought had crossed my mind, but my passenger door still hasn't sagged so I think I'm safe. Have you seen the price of a dimple set, I'd only use it once and then it would sit on the shelf forever, So basically that's a nah. As Duncan would say "That's 2 tyres".
Have seen guys 3D print them and get over 1000 uses from one die before needing to reprint them.
At about a $1 a set... I plan to give it a go!
  • Like 2
Please post your results in your build thread buddy, I can always re-visit the holes down the track.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
