I was trying very hard to keep my stuff-up a secret,,,like very in house,,, but seems thats dreaming.
Basically I stuffed up,,,went in to quickly and she woudn't turn, i was trying to catch a v6 supercharged commodore in my class and f**ked up.
Yes I have pics and vids,,,just no time for that malarcky,,, i have spend the last 2 weeks stripping her and putting her back together,,,12.30 nights every night, I'm rooted to say the least.
Cheryl Lives on,,,thanks to all the help from the following great people,,,in no particular order,,,i love you all
Pete and Jenna,,,thanks for all the parts,,,what would I have ever done without your help guys. THANK YOU
Duncan and Matty for all the helping put her back together,,,thanks both of you for all your time and effort,,,very much appreciated.
Mathew at Race Brakes Sydney for helping me out with new Discs and Pads,,thanks as always mate,.
So tomorrow a wheel alignment and get the front bar painted and she's good to go.
Cheers
Neil.
Seems some one was videoing Cheryl as well. At least she sounds great.
https://www.youtube.com/watch?v=m77HeRx7_t4
If the wheel alignment comes back bad and I can't take her to the SAU nats,,,I have a backup plan. I've been offered a drive of a very modified clubman.
Cheers
Neil.
I've been into (or up actually) that bank as well mate. Probably 10 yrs or more ago.
Mt Cotton is a difficult place to come to and try to go real hard first time you've ever been there. It caught out alot of very experienced hillclimbers that weekend, so you're in good company.
Good to hear it's pretty much ready to go again :)
Yep on the money there Harry,,very technical track to get used to,,,I'm usually pretty good at working out where I can go quicker and I had lots of help from an old mate from up there. Seems I picked the wrong spot to go in deeper. Bit shocked at the carnage that happened,,,lots of open wheelers crashed which is very unusual.
Ben there were a number of times going down the 1st loop that I and many others had the old shvinkter tightening up.
Time to start packing for Adelaide,,,wheel alignment is great.
Heres my in car,,,everyone loves a stack.
https://www.youtube.com/watch?v=FCmfgWy5sQA&feature=youtu.be
Cheers
Neil.
  • 3 months later...
  • 4 weeks later...
actually it drives beautifully and very predictably, and has done more motorsport in the last 3 years than any other SAU car I can think of. I'd have it in a second over most cars around the forums.
  • 1 month later...
Cheryl had a date with Yavus of Unigroup Engineering fame on Saturday and I believe she has fallen head over heals in love with him. After playing with her bits,,,I approved of cause and she now has 242kw's coming out of her rear end. I did ask if we could maybe lower her enthusiasm down a bit, but no was the answer.She does have a great rear end by the way.
That's using stock injectors,power fc, 040 pump, plasmaman inlet manifold,Z32 afm, FMIC and a Turbosmart boost controller.
We both left there very happy and I've entered her in next weekends VW Supersprint at Wakefield Park.
My only hope is I don't have to keep emptying her colostomy bag after every session.
Cheers
Neil
  • Like 2
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
