Well all that was an interesting read, dyno time will tell. I have some cameras including an endoscope so it will be easy to have a look on power runs. As usual I'm not chasing big power out of this new engine and if we see anything over 300 kilowatts we will be turning the boost down.
More updates, turns out my neighbor was a sign maker, so I bought some carbon wrap and got him to do the door trims that were in desperate need of a re-fresh, they turned out awesome.
I made a cable for the boost controller, so I can change from low boost to high boost from the steering wheel and make it so I can remove the wheel completely. I was just going to use old school phone cable but thought the wires were too small so I found a 240volt cable in ebay. Now to search all my boxes and find the horn pad and wire up the horns which I'll need to buy.
  • Like 5
  • 8 months later...
On 13/02/2023 at 5:03 PM, Neil said:
...Just as a heads up, I will die before Cheryl is sold....
So it turns out that is indeed what happened, and as Mel is not taking up racing and nor is their only child Lizzy the Great Dane, I am tidying the car up for sale.
As far as I can tell it is pretty much ready to go to the dyno for run in and tune, but I'll update in here once I know more.
  • Sad 6
So, starting with the rear brakes.
They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350.
Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff
Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
  • Like 1
Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well.
No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
  • Like 2
yeah for sure.....remember to put your tools away at the end of each day kids!
Actually it has been kinda nice working on the car, lots of memories of good times. I can pretty much hear him telling me off for stuff still.
Next, shocks/springs/swaybars
It has Sydneykid valved Bilsteins with HKS pillow ball hats all round.
Springs are Eibach race springs on adjustable height platforms, with helper springs in the rear to stop rattling. These are 250 all around but easy to change for something else if required.
Swaybars are powdercoated blue but would be Selby's/Whiteline solid adjustables, 21mm rear and 24mm front. Bushes and links in good condition
All in good condition, no sign of leaks/damage etc
Front lower control arm is standard with new ball joints, tension rod looks like JJR spherical. Front upper control arm is standard with adjustable bushes in the outside end
Rear arms are all nismo, surprisingly all the bushes at either end look standard but in good conditionimage.jpeg
Subframe has standard bushes with lock collars
HICAS has a lock bar with standard ball joints at the hub end
A few other things to round out the chassis mechanical checks.
Diff is nice and full of new oil, pretty sure it is Castrol VMX (I run the same on Award's recommendation). I didn't pull the cover to check, but I'm 90% sure the diff centre is a nismo mechanical (old school, not the gt pro).
Gearbox is also nice and full of fresh oil, not sure what it is but not redline.
Tailshaft bearing looks OK and a tailshaft loop is in place
Did a coolant pressure test overnight and it was back at 0 by morning....after some stuffing around I worked out it was the water return fitting at the turbo that was leaking, it all held pressure correctly once that was nipped up.
No brand mark on the radiator but I'd bet it is a 40mm cooling pro, with standard clutch and fan
I do need to remember to change the water out for coolant once the engine is run in but otherwise cooling looks all good.
2 minutes ago, fatz said:
How much ya asking drunkan
I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body.
Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right.
Everything else up to the throttle body was good.
Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt.
BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF....
Coilpacks are Splitfires with a factory loom in reasonable condition.
I didn't pull one put I bet the spark plugs are new as its a new engine
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
