On 17/01/2025 at 8:44 AM, GTSBoy said:
 there are better pumps that are near silent for less money from Ti.
What's the best straight swap fuel pump for an R32 Gtst these days? I looked at Ti website and found the 255 walbro kit for Skyline R33/34, but doesn't mention best Skyline
https://www.tiperformance.com.au/products/walbro-255lph-fuel-pump-kit-gss342/?srchy.source=srchy&_gl=1*1r4uarh*_gcl_au*MjQyMjM2NjAxLjE3MzcxOTQ5MDM.
When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit.
It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing.
https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD
Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
  • Thanks 1
Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum.
Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
  • Like 1
On 11/23/2010 at 9:27 PM, Neil said:
Oh I have the soldering skills,,,and Duncan has them as well. Here's some pics of my stalk,,,
Do tell mate.
Oh and check out the Veuve in the background,,,nicely donated by Mrs Handley,,,the girl is all class.
Cheers
Neil.
Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator.
Never considered it an issue other than it being a bit odd.
  • Like 1
There's no way they left the factory like that.
In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other.
The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
  • Like 1
Ah ok, interesting.
Yeah was gonna say as it wouldn't line up correctly, I imagine if they put the wheel that way it would mess with the wheel alignment.
How slightly is slightly?
I wonder if we have different thoughts on what slightly turning left means. I just tried this out and on mine you can turn the wheel somewhere between 45 to definitely less than 90 degrees before it cancels. Though I have to admit it feels much slighter in my memory than it is in reality.
See dramatic reenactment below.
Yep mine is more or less the exact same as yours.
To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
  • Like 1
*edit* see post below, this is not correct!
Not a huge update because still waiting for some fittings for the intake.
But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)
Sorry about the terrible pics but I think they are readable
With 70kg driver
  • Like 1
He still had the suspension dialled in for him!
I would have sworn the lowest weight he ever got to was 1300kg though :/
Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛
Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
  • Haha 1
OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver
And with a 93kg driver
I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
  • Haha 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
