I don't think she's cursed,,,nor does she need an exorcism,,,what she's needed was tender loving care which she has not seen for a while. She been getting plenty of it in the last 2 weeks let me tell you two boofheads. We started at about 2.30 and finished at 9.30,,,got all her under-belly done which was cool and for once I left happy.
I've left a message with the windscreen guy but I'll bet he's like almost everybody else and is still on holidays till next Monday. I'll ring him again on the 10th if I don't get a reply sooner.
Cheers
Neil.
The poor Yellow and Purple Beast is just a little stressed... With Uncy Dunc behind the wheel I know why too! HE'S A MADMAN! (And I love how he drives it!)
Neil, if you need a hand doing things with your beasty, lemme know.
I'm just starting to sell all my gear off... Going to start from a fresh base in 6 - 12 months time and build probably to the same standard as Duncs Yellow and Purple beasty.
so this wont be ready for MRA on the 30th? :D
That would be a big no unfortunately my good man.
World time attack I would think will be her 1st real hitout and I still won't have played silly buggers with horsepower.
Cheers
Neil.
Thanks for the kind offer Matt,,,look out mate we may just take you up on it.
Please don't tell me your considering a GTR cheater car,,,ha ha that rhymes.
Handles isn't a madman,,,he just owes one of Nissans finest. 21 years old and they are still handing current cars their arses.
Cheers
Neil.
Well in between Pete's HR31, waiting for machining, parts etc etc and the rain ive been stuffing around with Neil's car too, all be it slower than id like but trying to get the HR31 out of here sooner rather than latter, so I can finish my own GTiR.
Its no where near finished as yet, far from it actually but this is where its at.
Oh and a massive mention to my Fiance who has put up with me working on Pete's car for two weeks now and Neil's on and off this week, all while im meant to be on holidays doing nothing.....
Waiting for R33 full cage photos :)
Yea you and me both Michael,,, Gotta love the FIA's touring car standard intrusion bars instead of CAMS 3 bar ugly stuff. There wouldn't be to many cars running this quality,,,check this FPR pic,,,it's Paul Dumbrell's V8 supercar,,,very ugly.
Cheers
Neil.
Super taxi cages amuse me. We all have to adhere to a half door opening height for side intrusions even if the cage is homologated outside shedule J.
Yet have a go at how high they run their intrusions. I know why they do it and it makes perfect structural sence, but were not able to do it.
Same as the drop bar in the door opening. We have a few strict rules for door openings.
There are for and againsts when using the X intrsuions. They are actually way easier to fabricate than the bent bars beleive it or not.
what is the strength diference between the x bar that has 1 bar cut and welded around the other (like that v8 one), and the two bent bars with the gussett (like niels car, and WRC cages)
My logic would say a WRC would built to withstand bigger impacts, as side impacts are usually with a small diamiter tree (compated to being t boned by a car)
Cheers
Neil.
Feel free to take me up on it.
Just be aware I'm in Thailand until the 22nd of Jan... :D
And yes, alas I am considering a cheater car... Bang for buck, it's winning atm. But that decision is still a way off, the first thing to do is sell mine. It has to go unfortunately. It'll cost me twice as much to get it to Targa spec then starting from scratch.
What do you think Neil??
Its pretty similar to alot of other cages ive done like Ryan's
This one has the full roof X, different head support bars, intrusions and the windscreen supports.
The U type intrusions have a few advantages, the X bars obviously have a raised stress area where they are welded. The welded sections meet at fairly acute angles usually 50+ degrees, that leaves plenty of welded surface area, the welded area is just as strong as the original tube but the heat zones around the area can become a problem.
If they fail the X bars usually split open and create all sorts of nasty sharp edges etc not to mention the lack of protection.
The U bar obviously has no welded areas. It is also double tube diameter the entire length of the intrusion as opposed to the X bar which has a section usually an inch or so long that is only single bar protection.
For the U bars to fail they either need to spilt open (they are made from 750Mpa CDS as opposed to 350mpa), tear the welds off the main hoop and front legs (they are also tagged to the sill pannels and pillars where possible so not just relying on the hoop and leg welds in Neil's case) or finally they need to bend the legs and hoop, also needs to bend the hoop X, dash bar and roof supports to do so though...
So the U bars are stronger when done properly in double tube and they remove the chance of the X bars intersection failing.
The disavantage of the U bars is the additional work it requires. A normal X intrusion is pretty simple, straight tube two knotches, typically the cut tube is a 55-60 degree knotch welded together where it intersects and move on. sometimes fit two vertical gusset tubes if required.
The U bars need to be thought out alot more to make sure the bends line up and butt up against the other tube,it looks awful if the bends are different radius' or angles too so some though has to go into that too. I flatten the bend where they meet and MIG weld the two bars around the circumference, then make up two vertical supports from offcuts, finally cut the gusset plates and weld them in and with neil's car linish it all smooth so the whole gusset looks seamless to the intrusion.
Its easy to spend 3 hours on an intrusion bar. Worth the time though if the owner is willing to pay for it.
I rarely do U bars due to the extra time and cost involved. Not many people really bother either.
yeah guys windscreen man is the same as I was talking about. we go back about 10 years so was just helping him fill some orders. just been off on leave and computer free though so kind of fell off the map. back at work now though so neil if you've had no luck let me know and I will pick it up again. :)
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
