I have some stock GTR parts that I have removed from my R32 GTR for upgrades so they are up for sale. All parts working perfect before removal.
6x injectors $150
6x coil packs $120
2x AFMs $210
2x Ms pod adaptors and KN filters $100
HKS chipped ECU $150 (made 311hp at rear wheels on 12psi with N1 turbos)
3 1/2 inch titanium exhaust $700 (reduces to 80mm just before the cat and has scrape marks on bottom
from speed bumps. Loud tough sound and super lite Jap brand)
Exhaust is pick up only from me on the Gold Coast the rest of the stuff includes postage in Aus in the price.
I may only be able to get on the net once or twice a day so leave me a message and i'll get back to you asap
thanks
DSCF2931.jpgDSCF2933.jpgDSCF2936.jpgDSCF2934.jpgDSCF2938.jpgDSCF2939.jpgDSCF2940.jpgDSCF2941.jpg
https://www.sau.com.au/forums/topic/341838-gtr-parts-and-titanium-exhaust/
Thanks Simon.
Guys open to offers on the rest of the stuff and if you live interstate and want the exhaust it would be fine if you wanted to organise and pay for a courier to pick it up from me here on the Gold Coast.
What's the tape on there for? Just curious, it's not damaged at all behind there is it?
And just with the scrape? Is it dented slightly as well as scraped?
Is it full titanium or just the aluminium with the burnt muffler tip?
Negotiable?
Negotiable?
No mate it is not damaged under the tape.
Yes it is slightly dented aswell.
The exhaust is titanium and the muffler is stainless steel with titanium tip.
GT1.0z is actually full stainless, with their proprietry coating on the tip to make the burnt titanium effect
nice exhaust though, flows well and very light, good luck with the sale
Mate the exhaust is titanium but has a GT1.0z muffler on it.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
