I have some stock GTR parts that I have removed from my R32 GTR for upgrades so they are up for sale. All parts working perfect before removal.
6x injectors $150
6x coil packs $120
2x AFMs $210
2x Ms pod adaptors and KN filters $100
HKS chipped ECU $150 (made 311hp at rear wheels on 12psi with N1 turbos)
3 1/2 inch titanium exhaust $700 (reduces to 80mm just before the cat and has scrape marks on bottom
from speed bumps. Loud tough sound and super lite Jap brand)
Exhaust is pick up only from me on the Gold Coast the rest of the stuff includes postage in Aus in the price.
I may only be able to get on the net once or twice a day so leave me a message and i'll get back to you asap
thanks
DSCF2931.jpgDSCF2933.jpgDSCF2936.jpgDSCF2934.jpgDSCF2938.jpgDSCF2939.jpgDSCF2940.jpgDSCF2941.jpg
https://www.sau.com.au/forums/topic/341838-gtr-parts-and-titanium-exhaust/
Thanks Simon.
Guys open to offers on the rest of the stuff and if you live interstate and want the exhaust it would be fine if you wanted to organise and pay for a courier to pick it up from me here on the Gold Coast.
What's the tape on there for? Just curious, it's not damaged at all behind there is it?
And just with the scrape? Is it dented slightly as well as scraped?
Is it full titanium or just the aluminium with the burnt muffler tip?
Negotiable?
Negotiable?
No mate it is not damaged under the tape.
Yes it is slightly dented aswell.
The exhaust is titanium and the muffler is stainless steel with titanium tip.
GT1.0z is actually full stainless, with their proprietry coating on the tip to make the burnt titanium effect
nice exhaust though, flows well and very light, good luck with the sale
Mate the exhaust is titanium but has a GT1.0z muffler on it.
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
