No I'm not saying there wrong, it just seems so wasteful :banana:
Anyways I'm sure not all chefs do it...The chef at the local Chinese doesn't deglaze the pan, he just chucks everything into a very disgusting looking pan with burnt crap still in it. ;)
As long as you are not over the limit there is no law stating you can't have an alcoholic beverage whilst driving.
Really? A while back my mate who was at the time freshly off his P's decided to be a smartarse and raise his stubby to the cop sitting next to us. It was his first beer of the night and had only gone through 1/4 of it so he definately wasn't over the limit btw, but to cut a long story short he got defected (lol) but he also copped a fine for street drinking. It might be technically legal to drink and drive if your under 0.05, but just not anywhere thats public, and incidently most roads are public places
errr no...
the wine is used to deglaze the pan should be maybe 100ml's at most if cooking for 4 and this should be added to the pan while hot to strip the flavours from the bottom of the pan... it is not for the taste of the wine at all
the wine hits BOILING point instantly and will have 0% alcohol within a few seconds
hm, didn't know that.
but even though the wine hits boiling point instantly, i think unless its a dash of wine, there will still be significant amounts, it will be reduced but there is a lower limit to how much you can remove via distillation.
BUT, if there's very little wine used in the first place, then the alcohol remaining will be negligible.
There's this chinese wine chicken thingy that my granny cooks, its double boiled in a sealed pot with ginger, chicken and a whole load of other stuff, even though its boiled for about 45mins, the soup still tastes of the chinese wine and alcohol. but, its pretty awesome.
Edited by xALmoN
Drinking in street/public place is only an offence if the area is designated as a "dry" area by counsel by laws. They need to have signs in area stating same too.
Oops that happened in WA where I think it is a $200 fine if you get caught drinking in any public place, I assumed victoria would have the same laws but I guess not
You can choose to have a blood test but the alcohol levels decrease MUCH faster in your breath than blood. If you were say 0.07 with breath and had blood taken a hour later you would most likely be 0.08+.
In most cases people's alcohol level are on the rise. They keep rising generally for about 1-2 hours before decreasing. Unless it's just mouth alcohol.
it all depends on the person though, that's what it basically comes down too.
How fast they matablize the alcohol...
Nah, there isn't a law saying you can't drink anywhere in public, but there is designated "dry" areas...which I can't of to many places that aren't..
because i am so nice/was bored @ work I decided to make a tut on carbonara...
cook garlic
add bacon - cook more
bacon is cooked... notice epic bacon flavour helplessly trapped on pan...
deglase pan with wine
epic bacon flavour now released and ready to be consumed by hungry human
place egg in bowl.... i use an extra yolk for flavour
add parmesan and some parsley and black pepper
whisk that shit
add cooked pasta to pan... in this case it's housemade tagliatelle
add pan contents to bowl contents and mixy mixy
add some shaved parmesan for texture/flavour
put in bowl... garnish with raw egg yolk for the lucky eater to mix through themselves
and that's how you make a carbonara...
some people add cream, but traditionally it's not really supposed to be there :)
wut
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
