Hey guys im just wondering what is the safe limit other then the standard 7psi to run on my ECR33. Im thinking of boosting to mayb 10psi for a quicker spool getting a lil bored with the 7. I havent got much done to the car just intercooler and 3" exhaust. Can anyone lend a newbie some advise? Id rather ask to be safe then going stupid and hurting my car.
https://www.sau.com.au/forums/topic/341850-boosting-up-advice/
10-12 psi is the norm.but have heard some running 14psi. i used a turbosmart manual bleed valve and it was 12psi dropping to 9 psi at redline.
hmm sounds good i just got a turbotech version so ill try to set it up for 10-12 ps1 thanx m8 =D
make sure you don't destroy your turbo if you have the stock one.
they have a ceramic exhaust wheel and if you push them too hard they can shatter. i wouldn't go above 10psi if you want to run it reliably day in, day out.
thanx for the advise ill aim for 10psi =D
factory ecu will have pretty rich mixtures though so you really need to get the AFRs and timing fixed up as well, not just boost. Nistune is a cheap ecu addon ($400 or so from memory) - that and a half decent dyno tune with 10PSI on the turbo and you should be sweet
I might leave the nistune aside as i dont want to waste 400 on it atm ive got plans for the future for this car and think id be better off waiting till i can get an aftermarket ecu or a microtech that way i have full tuneability.. But thanx for the info. So ill need to dyno my car after fitting the boost bleeder?
Nistune is now the preferred ecu by many of the popular import tuners .. it's hardly a waste of money. I'm not sure where you get that it doesn't have "full tunability"
And of course you should dyno it after messing around with boost unless you don't mind your engine pinging it's head off. As I said, get the mixtures and timing fixed up - no point in doing up the boost as that will only introduce pinging and the longer you run it like that the more damage you do to the engine.
how is upping the boost going to induce pinging on the stock ecu compared to getting the thing tuned? the stock ecu runs relatively sedate timing and more fuel than required. you have more chance of pinging with a tuned ecu as they will increase the timing and reduce the amount of fuel. if you have pinging at 12psi on the stock ecu then you have a fuel issue (such as a dying fuel pump) or your timing is majorly advanced, or you have poor fuel.
the stock ecu will start to get to the upper limits of it's range at about 12 or 13psi. if i was you i'd just go for 11 or 12psi. that will keep you in the range of not hitting any ecu limit as well as still be ok for the turbo. that said, i had a remapped ecu and i was running 14 to 15psi on the stock turbo for quite a while and never had an issue (and others i know have done the same), while other people i know have blown the stock turbo at stock boost. it is just luck of the draw really.
as for the nistune, value for money they are probably the best ecu upgrade on the market for skylines. they are about half the price of a powerFC and will give you pretty much the same results. only downside is that you don't get the wank factor of a hand controller.
oh and turbosmart boost controllers aren't worth the money. the cheap $30 turbotech ones hold boost much better from my experience.
nah, with the stock ecu if it sees more air that it has mapping for it just chucks the shits and shuts down. below that point though the ecu has mapping up to the point that the AFM maxes out (generally speaking, although in the case of the skyline ecu it has a secondary protection in it which kicks in much below this). the ecu won't start leaning things out until it gets to 100% of the AFM voltage, or 100% of the injector duty cycle. which as most people will tell you happens at well above 200kw.
in my case, i was running 12psi and my afr's were still down around 10.5:1, while a tuned ecu would be aiming to have them around 12:1, which is about 15% leaner.
even an aftermarket ecu should be tuned to handle more airflow than what it was actually tuned for. it might not be all that accurate, but it should still handle a boost increase as the tune should've been done to cover the load cells higher than what it actually normally used.
Thanx for the info once again mad =D yea ive heard nuthing but good things from this torbotech brand and for the price i thought it was worth it
there you go, learn something new everyday. Thanks for the concicse and easy to understand explanation.
Now I hope you're right so I don't have to un-remember this :P
mad is correct. The ECU has a map with rpm on one axis then "load" (basically AFM reading) on the other axis, and adds fuel based on what the map says. So when the airflow goes up (say if you up the boost) you hit a different cell. The standard map is setup such that if you're outside the cells that the factory expected to see, then the implication is that something has gone wrong, and therefore its a good idea to try to protect the motor. So those cells run a lot of fuel and very little timing to that end.
nope. that was just for the T piece, 2 hose fittings and spring. i had a bearing at work, as well as a bolt and nut, although i had to tap a new thread into the fitting as the original one was different to any bolt i could find (i think partly because it is tapered)
i made a copy of a turbotech boost controller with stuff i could buy from autobarn and it worked well too, but worked out to be a few dollars more than buying a turbotech
You foolish fool, thinking you could beat globalisation like that.
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
